- Thank you received: 26
No such luck on upgrading the 17A tracks, your stuck with 7M,3T,17A 8.00" pitch.
You can upgrade to segmented sprockets with a 4S9005 adapter ring plus two 3S9138 and four 3S9139 segments per side if you can find them.
Some komatsu tracks will also fit the 17a- not sure which model but I have seen some converted which also provides the crocodile link making separation easy. I have some for my 17a which came with the machine and they are the same pitch as the worn ones of the machine.
Thanks for the photos from which I can see that the upper block mount for the cable blade on mine has been raised some 6" or more. Mine was a logging machine and I guess the idea was to get the blade higher for tree pushing.
Interesting blade modification on yours. Never seen that adaptation before.
Yes the pressure gauges are still available from Cat or Fleabay.
The turbocharged 17A is one of my favorite tractors, and one that so far has eluded me. I hope you can get it.
I have two 3T and three 17A chassis. Four of them have pretty good undercarriage, definitely ten times what yours has on it. One 17A chassis I have has brand new everything, new rails, new track pads, new rollers, new carriers, new idlers. I don't think I want to part with the brand new undercarriage, as I'm saving that for when I find my own turbo 17A.
The others, however, are available. Freight from Bakersfield, California would probably be difficult. I know this guy, though, who lives in Moose Lake and makes all kind of crazy trips hauling crazy stuff, so maybe something could be worked out.
I can get measurements and pictures, if you get it and if you like.
Pete.
I looked up the Komatsu tracks. Yes, they are 8.00" pitch, available with alligator link but non of the part numbers match the 7M,3T,17A numbers.
I don't have the actual dimension information to check how close they may be.
Garlic: How bad do want a 17a? I may consider selling mine, if you can entice me with a good offer....JManThe turbocharged 17A is one of my favorite tractors, and one that so far has eluded me. I hope you can get it.
Pete.
Hi, Dieselholic92.
I don't have the cross-match charts to compare them but it would not surprise me if companies like Berco and Italtrack also had matching chains, sprocket rims, etc..
www.itramerica.com/undercarriage.html
www.berco.com/en/home-en/
These people might be worth looking at for new or used parts:
www.bmcdowell.com/heavy-equipment-parts.html
www.tractorparts.com/
Here is a link to an "Undercarriage Basics" PDF that even shows why fitting tracks backwards increases wear on bushes and sprocket teeth - not bad even it is aimed at Dresser products - NO 8.00" pitch shown.
www.tractorparts.com/PDFs/undrcarguide.pdf
I'm told that Komatsu D60/65 chains will fit
They are coded 144 32 11133 and seem to be more available than D7 chains aftermarket
We have a Komatsu D65EX-12 and was quoted on tracks with Cat D6R chains fitting it if that is any help .
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
