- Thank you received: 3
I have a similar problem. I have a D6 which I think is about 1954/ I have the serial number somewhere, but not at hand.
My problem is that the pump does not seem to be pumping. To get the blade to lift, I have to hold the control in the UP position for a long time and it inches up slowly. I do not have any user manual or drawing or picture of the hydraulic system, which makes it hard to know what to do on it.
I assumed that the tank in front was the hydraulic reservoir, and I checked it and it is full of oil, so I assume it is not a lack of hydraulic oil that is keeping it from lifting the blade. It worked fine before.
So, I assume that for some reason that the pump is not pumping like it should be. So, what is my next step? Should I remove the pump and reservoir as was done above. If so, what do I do then? Can the pump be rebuilt? Are used replacements available? I would appreciate any help on this. Otherwise the tractor runs great.
jim nicholson
Turns out I did buy a service manual but does not detail the hydraulic pump. Go figure!
Nothing to do with luck. Cat had a book for each attachment. So hydraulics are different books than dozer blades even if used on the same machine.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
