D2 injector problem
2 years 6 months ago #236436 by smokiejoe70
I have a late model D2 serial # 5U 13773. I have rebuilt the transfer pump and am trying to get it started. I have fuel all the way to the injectors but get no smoke. Any ideas on how to get these valves to open?
2 years 6 months ago - 2 years 6 months ago #236437 by Rome K/G
Replied by Rome K/G on topic D2 injector problem
Fuel to injector nozzles or pumps? There are bleed screws behind the pumps [original ones]. Throttle open while bleeding nozzles? Throttle closed when bleeding pumps.
Last edit: 2 years 6 months ago by Rome K/G.
The following user(s) said Thank You: Fat Dan, smokiejoe70
2 years 6 months ago #236438 by smokiejoe70
Replied by smokiejoe70 on topic D2 injector problem
I have done both as per manual specs but no smoke
2 years 6 months ago #236439 by Rome K/G
Is the throttle opened or pulled back enough? Compression lever in run position?
2 years 6 months ago #236443 by Old Magnet
Replied by Old Magnet on topic D2 injector problem
and are the pump lifters making full stroke?
2 years 6 months ago #236449 by Fat Dan
Replied by Fat Dan on topic D2 injector problem
Yup , did that before.
Got excited because I ran out of fuel while on the road and forgot to put the compression lever to run.
ACMOC Membership
2 years 6 months ago #236457 by Rome K/G
The following user(s) said Thank You: Buddy, Fat Dan
2 years 6 months ago #236470 by josh
Replied by josh on topic D2 injector problem
Could the rack be stuck?
2 years 6 months ago #236477 by smokiejoe70
How much pressure does the transfer pump.have to produce minimum to open the injectors. I had it running for about 5 seconds but it died and won't restart.
2 years 6 months ago #236478 by Fat Dan
The transfer pump puts out just a few pounds of pressure about like an auto, I'd guess, 5 to 8psi. A quick check you can use a temp gravity feed tank or an electric fuel pump that should be of pressure.
Good luck
ACMOC Membership
