D69U hydraulic pump removal
Thank you received: 153
2 years 6 months ago - 2 years 6 months ago #236038
by rax200
Need a photo of the cartridge and part number.
What type of pump / model
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Last edit: 2 years 6 months ago by
rax200. Reason: Add pump type
Fat Dan
Thank you received: 63
2 years 6 months ago #236042
by PhilC
Before spending thousands on a new pump you might be better off running some tests. If the pump has enough pressure to lift the machine smoothly and is not making any unusual noises (which may be hard to tell) it might not need replacing. I would get someone to do a pressure and flow rate check on the pump.
If you already have the pump out then pull it apart and do a visual inspection of the vanes and the cam ring. If you do pull it apart make sure you keep everything clean. Hydraulics do not like contaminants.
From what I have read in this thread and your other valve thread, it sounds like the pump is not the problem.
Thank you received: 7
2 years 6 months ago #236049
by yellercat
OK, thank you both.
Pump is the 6F9393 Cartridge is 8F3445
Have some reduced pics now also. Looks rough to me, but may be that is will be usable....
D6-9U
Fat Dan
Thank you received: 620
Thank you received: 191
2 years 6 months ago #236052
by D4Jim
Unless it is just reflections in the photos, the ring appears to be shot. The vanes appear to be pretty good compared to the ring.
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Fat Dan
Thank you received: 387
2 years 6 months ago #236069
try your local hydraulics shop they might be able to help you. its worth the ask anyway and you'll atleast get a qualified opinion is it knackered or serviceable.
Fat Dan
2 years 6 months ago #236071
by PhilC
I agree with D4Jim. Unless the vertical lines in the ring are from the lighting or from where the vanes have been resting then it will need replacing. Looking at the rest of the pump it appears to be in good condition. It is hard to tell from looking at photos but if you can't feel any grooves in the ring then it should be usable.
Fat Dan
2 years 6 months ago #236072
by Rome K/G
The brass side plates are shot! thats where you loose pressure when those get grooved.
Fat Dan
Time to create page: 0.208 seconds
