D4 7U bevel shaft same as 955 12a?
Thank you received: 409
2 years 11 months ago #232047
My D2 has recently-fitted sintered bronze packs and the steering is as smooth as silk - really really nice.
Thank you received: 11
2 years 11 months ago #232054
by Zzzopp
Having trouble finding the gaskets for these areas.
1- Rubber gasket between clutch cover and transmission cover.
2- felt seal over gear box.
3- felt seal over bevel gears.
The parts book doesn’t show detail very well. Anyone have any ideas for gaskets or something to seal compartments?
Thank you received: 63
2 years 11 months ago - 2 years 11 months ago #232060
by PhilC
I only have a 6U1-up parts book but the part numbers from it are the same as the 7U.
Can't find a gasket on either the transmission housing nor the clutch housing
3B889 2of
3B880
3B881
3B882
2 of each
Last edit: 2 years 11 months ago by
PhilC.
Zzzopp
Thank you received: 153
2 years 11 months ago #232063
by rax200
Hi Zzzopp,
I have marked in red the gasket that you will require to put it back together in the images,
regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Zzzopp
Thank you received: 387
2 years 11 months ago #232064
you could probably use neutral cure rtv slicone for those areas although there has to be a reason why they used felt. these old things dont have gear box breathers do they? so the felt may be to allow for thermal expansion and release of that vapour pressure.
you can buy felt buy the roll from craft supply joints like spotlight.
smear it with grease both sides to help it seal.
another place to try is engineering and bearing suppliers.
Zzzopp
Thank you received: 45
Thank you received: 142
Thank you received: 20
2 years 11 months ago #232068
by 8C 361
As I recall years ago I got square cork from Cat. I cannot remember if it was 1/4" or 3/8" but definitely square cork, whatever fits in the channels. Are they not available from Cat any more? I am sure square cork can be sourced.
Zzzopp
Thank you received: 620
2 years 11 months ago - 2 years 11 months ago #232069
by Rome K/G
The updated seals are: Seal Group 6K0856 Effective with Ser.No, 7U33913 For Bevel Gear Shaft and Cover.
2-4K7470 Seal
2-4K7472 Seal
2-6K0949 Seal
2-6K0950 Seal
2-4K4390 Seal
8-6K0840 Pin
4-4B4280 Washer
2-5B2383 Nut
1-36247 Form Instruction
Rome K/G.
Zzzopp
2 years 11 months ago #232077
by rax200
Hi Zzzopp,
I just checked with Cat and all the gaskets/seals are available from them.
If the part number is 3b882 it converts to 3b0882 as some parts guys dont know how to update them.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
Zzzopp
Time to create page: 0.184 seconds
