Plow day
Plow day
Thank you received: 49
3 years 1 month ago - 3 years 1 month ago #230674
by kracked1
Local plow day yesterday. My D47U and tandem plow set up I put together. 5x14 worked great.
Last edit: 3 years 1 month ago by
kracked1.
Thank you received: 191
3 years 1 month ago #230676
by D4Jim
Nice picture and particularly of the two plow hitch setup.
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
kracked1
Thank you received: 45
3 years 1 month ago #230678
by Sasquatch
Nice setup! I’ve been dreaming of an on-land hitch to pull two 3 bottom plows in tandem behind my RD6, I think it would be great fun. Is that Gary in the seat?
Bmr
3 years 1 month ago #230687
by kracked1
Good eye, that is Gary. He came down to see it in action and had to make a round. I can help if someone wants to build one.
Bmr
Thank you received: 142
3 years 1 month ago #230688
by bursitis
i have a JI Case 5x16 drag plow. since my D46U is narrow gauge can i adjust things to pull this as an onland set up?
Thank you received: 285
3 years 1 month ago #230690
by gauntjoh
I believe that with a crawler you should always plough “on the land” rather than in the furrow. Do not pin the drawbar so it can swing freely and adjust the plough drawbar so the plough pulls straight.
kracked1
Thank you received: 409
3 years 1 month ago #230691
I'm looking forward to plowing with my 5U this fall - I haven't used anything but wheel tractors previously. I'm running slicks on it so I'm not sure if I'll be able to put all the power : ) to the ground but it's in sandy loam so I'm sure it'll be fine. The bigger problem I'm guessing will be trying to keep straight lines!
3 years 1 month ago #230695
by kracked1
That will have the center of draft at 46.5 inches from the inside of the furrow wheel. 5 x 16=80/2= 40 +4.5 inches (which is the magic number for 16 inch bottoms to compensate for average draft) +2 inches for clearance between furrow wheel and furrow wall.= 46.5 inches. Set the plow drawbar as straight as possible so your hitch pin is at 46.5 +- an inch or two. Your 6U should be 68? inches wide which would be 34 to center. 46.5-34 =12.5 inches from furrow wall. Also with a crawler having the hitch so low you need to set the point where the hitch hooks to the main frame of the plow as low as it will go. Other wise it will want to pull the back of the plow out of the ground.
bursitis
3 years 1 month ago #230699
by D2MOVA
Have probably replied to this before but you have to remember trailing ploughs were originally pulled by horses they could not steer them I have ploughed acres and acres with a D2 and a 3 and 4furrows on flat and hill country always the tractor on the land drawbar sliding from centre to the right when it gets steep turning uphill you just move toward s the furow to keep the plough in line will try and post some photos
Plow day
