D4 7j fuel pressure
D4 7j fuel pressure
3 years 5 months ago #227001
by dieselcowboy
Ok fellas I've done everything I can think of to get fuel pressure on my d4. New gaskets on filter housing plates. Tried bleeding it several times. Pulled a large plug next to the fuel inlet tube on the bottom. It only had a long spring in there. Filter housing is full but no pressure coming out. Any ideas what I can look for or check?
Thank you received: 191
3 years 5 months ago - 3 years 5 months ago #227022
by D4Jim
In theory the fuel flows from the tank to the transfer pump which gives the pressure to the filter housing. Could be a faulty gauge or the transfer pump is shot. Do you have your manuals yet?
If you changed fuel filters and bled the system the problem is probably the transfer pump. Usually Not to tough to fix. If you crank the engine and don't get spurts out of the opened vent at the top of the fuel tower, probably no pressure from a faulty transfer pump. If you get fuel spurting out it is a faulty gauge.
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Last edit: 3 years 5 months ago by
D4Jim.
Thank you received: 409
3 years 5 months ago - 3 years 5 months ago #227026
First verify that the outlet valve on the diesel tank is open. The line on the valve stem should be inline with the valve body to be open (across means it's closed). Then pull the relief valve adapter off the transfer pump (it's on the inlet side) and check that the plunger is in good shape and free, and can seat ok in the adapter, and check that the spring is ok. If a fault is to be found here, it's usually that valve is failing to seal
neil.
Thank you received: 341
3 years 5 months ago - 3 years 5 months ago #227041
by edb
Hi,
scan below shows the bypass or relief valve and spring on a D4 but the D2 is virtually the same.
Early valves were hard plastic and tend wear grouves across their seats and sometimes rust or grouved housing faces can cause leaks and low pressure, later valves are alloy with a rubber face.
The light springs collapse in time and a gentle stretch works wonders--the coils can also weaken due to rusting from water laden fuel.
Fuel blockages between the tank tap and the transfer pump are a factor too. Dirt and rust can build up at the transfer pump inlet and low points in the supply tube from the tank.
Rust flakes and foreign objects can clog the tank outlet before the tank tap also.
Normal fuel pressure on these is around 15 to 20 psi. see below.
FYI. at the Dealer we did a test on the Part Numbered gauge as described to establish the gauge graduations vs. pressure readings.
edb.
3 years 5 months ago #227043
by dieselcowboy
Have a service mans which does t even go into injection. Just found and ordered a parts manual. I'm not real sure the check valve is in place under the spring. Pulled it and nothing came out with the spring. May have to mirror in there and see what there is. Either a hole or valve. I must have a fairly early machine serial 7J102. Finding only one manual available for sale going that low.
3 years 5 months ago #227045
If the check valve is missing, you won't have any pressure (unless someone blocked the relief hole)
Thank you received: 387
3 years 5 months ago #227055
there is a seperate book for the main engine i assume there is for all of them. i have a book for the d315.
3 years 5 months ago #227070
by dieselcowboy
So I did find a metal plunger deal in the relief plug. Tapped on the housing with a hammer and it finally dropped out. There was no rubber or plastic on the end of it.
I’m assuming the transfer pump is the 2 gears behind a plate on the bottom end of the filter housing ?
3 years 5 months ago #227071
Yes that's it. Pick up a new plunger. Is the spring ok?
3 years 5 months ago - 3 years 5 months ago #227074
by dieselcowboy
Hey Neil yes it seems to be. It has to be compressed to start threading the plug in. Here are some pics of what I'm working with.
D4 7j fuel pressure
