1st time running the D13000 genny full throttle with 40kw load. Short video.
Thank you received: 43
3 years 6 months ago - 3 years 6 months ago #226354
by ag-mike
Febuary start & load.
1st time for me to load it enough to clik it to highest throttle notch. Using 3 15kw 3ph resistive type heaters trying to heat over to nw ohio! It's running at 900 rpm.
Last edit: 3 years 6 months ago by
ag-mike.
Thank you received: 632
Thank you received: 48
3 years 6 months ago - 3 years 6 months ago #226367
by mog5858
that's a great sound thanks for sharing
mog5858. Reason: spelling
ag-mike
Thank you received: 620
3 years 6 months ago #226370
by Rome K/G
Must of worked it was 50 degrees here yesterday and supposed to 54 today, thanks Mike, felt good!
ag-mike
Thank you received: 409
3 years 6 months ago #226371
Very nice Mike and this is what I like about generators and ag work, that it's steady and at full power. That engine sounds really nice. Looked like the pointer was showing about 450 rpm or something - is it reading half the actual rpm? Could use that to melt the ice dam off the roof! : )
ag-mike
3 years 6 months ago #226372
by mog5858
if you have an ice dam on the roof that means your losing hear out of your house Neil. better insulate it a little better lol
ag-mike
Thank you received: 279
3 years 6 months ago #226373
by Deas Plant.
Hi, agmike.
GREAT stuff. Thanks for sharing. Those D13000 havva nice bark to them when under load.
ag-mike
3 years 6 months ago #226374
by ag-mike
Yes, Tach reads 1/2 speed, i haven't been able to find the right stewart warner reversing adapter OR a 1000rpm ccw tach.
thanx.
3 years 6 months ago #226377
Right Mog! I was casting a critical eye around the neighborhood because I did have some ice buildup; not too bad but a bit more than I really want. But then I looked at my neighbor's roof and he had a huge amount at the terminal of one of his valleys, and this after putting 3000# of extra insulation in along with fitting more baffles and sealing up the light cans. Turns out everyone in the area had significant ice so I expect the climatic conditions exacerbated the icing - snow, melt, freeze, snow, melt, freeze. We have had a bit of that. This season's been better (i.e. colder) but still out of whack
Time to create page: 0.160 seconds
