D2 electric starter conversion for main engine
Thank you received: 251
3 years 8 months ago #225135
by juiceman
That’s different. Lowell C. has a CAT that has a hydraulic driven motor on the back to start with. Thanks for sharing.
Thank you received: 13
3 years 8 months ago #225138
by TractorDanD2
Yes, I guess it,s innovative. But must be dangerous. I will not be trying to use it to start the main engine. Just imagine reaching in over the rotating ring gear to knock out the PTO once the engine is running.
Thank you received: 409
3 years 8 months ago #225143
Wombat's mate Pertu in Finland used a hydraulic motor in place of the pony motor on a 36A to get it started. There's a video of it on youtube where he uses his John Deere to supply the hydraulic power to the motor. I don't know if the motor had a Bendix or some other disengageable pinion on it?
Thank you received: 191
3 years 8 months ago #225146
by D4Jim
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Thank you received: 387
3 years 8 months ago #225150
neil you woudnt need a bendix if you drove the original intermediate gear with the hyd motor as you would use the factory clutch mechanism the only thing needed is to mount everything in place
Time to create page: 0.161 seconds
