cat 941 flexible coupling removal help
3 years 11 months ago #222836
by wlf89
is there any tricks or pullers needed to remove the flexible coupling off of the flywheel side? i got the 6 bolts out and have banged and pryed on the coupling and cant get it to budge. the transmission wont come out with it still on there.
if i cant get that off all i can think of is bolt the trans back up, and remove the torque converter first then the rest of the trans.
Thank you received: 15
3 years 11 months ago - 3 years 11 months ago #222838
by Glum
I could be wrong but I don't think you should have to remove the section bolted to the flywheel. Just the flange on the torque converter shaft should suffice.Have never needed to on a D4 at least, which I think is all but the same in that area. It is a tight fit and sometimes you need to mess a bit with the angle that the trans is hanging at.
I recently had a D4 trans and converter in and out a few times getting the shimming right for correct pinion to bevel gear tooth contact.
Last edit: 3 years 11 months ago by
Glum.
3 years 11 months ago #222843
by Glum
Here is what OM is talking about.
I've not seen the centre bolt version myself.
Thank you received: 279
3 years 11 months ago - 3 years 11 months ago #222844
by Deas Plant.
Hi, wlf8.
I have never had to remove that flange but I have had to replace the rubber couplings a couple of times. They always had two bolts in them, one from each side, and both had to come out before you could get the rubber coupling out.
Been a LONG time since I had to do it - 2008 or so - but that is my recollection.
Deas Plant.. Reason: spell-ink
3 years 11 months ago #222849
by wlf89
mine just has the 6 bolts around it, no center bolt. i tried every angle i could to get it out but cant get it lowered down without hanging on the front flange or the pinion clearing the hole it slides into.
Thank you received: 39
3 years 11 months ago #222854
by gemdozer
I removed a transmission from 941 for parts and not sure he was serie 70H made FRANCE but no remember if motor was removed
3 years 11 months ago #222859
by Glum
Are you trying to drop the trans or lift it out? You need the machine on blocks to take it out the bottom.
3 years 11 months ago #222860
by wlf89
How much clearance do you need? Has the engine shifted on its mounts?
i need about a inch or so. i wondered if the engine was further back than should be. the rear mounts look like are adjustable butt he front is just a bolt going down thru a hole so that doesnt have any adjustment does it?
