- Thank you received: 251
I have the D8L -SA build sheet somewhere, I just have to find what box it ended up after a few moves and potential moves. I believe the L SA’s were exchanged for Deere 9400T’s when they came out if I remember the story correctly. The company was also shipping them to be used at their NSW Australia farm operations as well.
Juiceman ripping in a growing orchard... that sounds like a good way to remove all the buried drip or sprinkler lines. I guess my grandfather tried that in an Almond orchard that wouldn’t take water ( furrow irrigation days) in the late 60’s with a D7 and the driver said he looked back and saw the ripper pulling out trees as soon as he put it into the ground. Later they used a AC-Oxnard 400 with only the center shank behind the D4D or 7U.
TomTrack, Are you sure you aren't thinking of Glen's 49A D-9? He didn't own a 46A D-8 that I ever knew of while at the SM tractor show. He had a couple of 36A's though and a few 14A's too.
Gee, it sure looks like a H model D-8 to me.
Thanks for all the info Wombat. What is this marine clutch? Pardon the newbie questions but it has a conventional powershift transmission that uses planetaries for gear reduction but no old school countershaft type transmission? And the marine clutch is in ot out and no slippage like a normal TC? And what about the 76V and 36 series? Were they the same way or similar to an old 14A etc...?
One weakness was they did not handle high tongue weight well. In the 1980's something called a Yielder no till seed drill became some what popular in dryland wheat and barely seeding. A 20 foot wide model held more than 20 ton of seed and fertilizer plus the drill was a heavy thing itself. A operation running D8H 36a's decided that was not enough tractor and rented a D8L SA tractor to pull one. Was a consent battle to keep the rear rollers/idlers in D8L. Did not take many years to decide that was not the seeding outfit they wanted.
CR that last picture in the cab looking out at the other 2 machines is great You’re really covering some acreage there!
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
