- Thank you received: 409
Could do with a few icy moments here - been in the 90s for the last couple of weeks - been hell on the golf course : )
Hi Mike,
it almost goes without saying that if you have found that the Accessory Drive Shaft is not turning then the Injection Pump is not turning also and seizure in the drive or pump may be the source of your sheared key--if that is what you find--check the Acc. Drv. Shaft front bearing for seizure, ditto the Injection Pump, its drive tang and slot for damage if pump is seized and also the Governor due possibly from low oil level in the Inj. Pump sump.
If the Acc. Shaft front bearing is seized check the oil supply and pipe work to that front bearing cage and that the bearing oil hole is aligned to the supply port.
Looks like front timing cover off to do most of this checking/repairs--not a nice job these icy mornings you are having at present.
Well, I knew it would be something simple causing the problem, sadly, solving the issue is not so simple....
The fiber camshaft gear has stripped some teeth, that explains why I saw some oil sitting on top of the aircleaner, I guess that suggests bent valves and possibly damaged pistons, and obviously the reconditioned head I fitted only 10 hours run time ago, needs to come off again.
I took me 7 years to get this engine back together and running, this poor old tractor had been abused by a whole congo line of drop kicks and deadbeats.
Oh well, I always say, the day I never learn something new when working on these old Cats, is a day I've wasted.
Mike
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
