D2 no start .... now started with blown head gasket
Thank you received: 9
4 years 1 month ago #221269
by TOGNOT
Thanks Andrew - I’m sure i can find one up here in the states, but i would like to see a picture of the one with a nut welded to it as i may try this my self.
Thank you received: 6
4 years 1 month ago #221326
by Andrew
Photos of 5 3/4" pre. cups with nuts welded to facilitate removal.
These came with a parts lot I bought a while ago.
4 years 1 month ago #221369
by TOGNOT
Thanks for digging those up and taking the pic. Ill follow up with what ever works on this end.
4 years 3 weeks ago #221879
by TOGNOT
I have been working on getting the suspected bad prechamber out. Apparently it likes where it resides now and has no desire to vacate.I welded a bolt into the PC hoping i could unscrew it wit impact gun or cheater bar. Nope.
I spent a couple hours today drilling out the threaded end of the PC. The remaining material is very thin. I heated up the threaded area ( again) and tried a breaker/ cheater bar. Nope.
I assume the PC is rusted to the head where there are no threads. My next thought is a truck stop with 1” impact air guns ?
Thank you received: 620
Thank you received: 341
4 years 3 weeks ago #221884
by edb
on these older engines Cat used an Allen head set screw screwed into the side of the cyl head as an extra security to hold the pre-chambers in place during service.
P/No 4B9746.
4 years 3 weeks ago #221888
by TOGNOT
Edb, thanks - another pointed that out and I removed the screw. BUT - i realize now that it too was rusted down to almost nothing on its tip that extended into the prechamber. Tommorw ill run a drill in there and make sure none of it is left against the PC.
Thank you received: 409
4 years 3 weeks ago #221893
On my 3J, the set screws are there, but they're short of the chamber so don't actually retain it. I think the previous owner had them in there to fill the hole
4 years 3 weeks ago #221901
by edb
I believe that over time it was found that the screws were not necessary, also there were likely many chambers ruined by people drilling thru the chamber when drilling a new lock position for the screws after the chamber had located in a new position after removal and refitting.
I was taught to cut the screws short at the Dealer back in the day.
4 years 3 weeks ago #221902
This has been tackled before on here, unfortunately no thread size was mentioned. If my memory is correct it might have been "Steven" on here.
Time to create page: 0.223 seconds
