D2 no start .... now started with blown head gasket
Thank you received: 9
4 years 2 months ago #220188
by TOGNOT
D2 3J was parked for a year (inside). Always fire right up, especially in summer, with electric start. Long story shorter :
Would only fire with a shot of juice. Drained fuel ( was stinky - not normal smell) went through the bleed sequence and got her going. ( real time about 4 hours : (
Right away I noticed gray / white smoke and it never cleared up. Cylinder balance ( crack injector lines) shows #1 is dead.
Radiator is bubbling. Seems I have a head gasket leak now ?
I know “anything” is possible ... but ever heard of head gasket going bad while sitting ? - jest kewr-e-us...
Thank you received: 142
4 years 2 months ago #220199
by ccjersey
Had simular situation. Ended up being a Precombustion chamber
Seems to be more common than gasket AND a lot easier to check out and fix. I would start there.
Thank you received: 118
4 years 2 months ago #220209
by Ray54
If the seats in the head are not real smooth, I have had trouble sealing the washers. i believe the old time ones where copper. All the modern ones seem to be steel with copper paint. Engine rebuilder found real copper ones at McMaster-Carr. They sealed and ended my problems in that engine. Have another I just don't seem to get to.
Thank you received: 251
4 years 2 months ago #220210
by juiceman
That is a real rain on your parade moment Jack!
Yes, sounds like bad precup or head gasket issue.
You’re pretty savvy, so I’m sure you’ll get the little D2 back to 💯 soon.
Haven’t heard from you in quite some time. Always wondered what became of you and your D2.
Maybe life was quieter without all of the extra iron you had? Please let us know how things progress. JM
4 years 2 months ago #220217
by TOGNOT
Thanks all, and JM. We had a fire here ( near keene, CA) and it got within 15 ft of my building where little D2 was sleeping. I pulled him out with a chain, and after fire was out - that’s when my new problem began. ( down hill out of building - uphill into..)
SO I have been reading and I guess the copper ( or soft metal) seal could allow combustion in to the cylinder ? I will pulli injector and Then prechamber ( if I’m lucky from what I have read). If that seems good then the head comes of next.
Thank all
Thank you received: 42
Thank you received: 6
Time to create page: 0.195 seconds
