- Thank you received: 0
Hi waltini,
if your calculated hull speed is 8.5 knots and 8.5 knots is what you are currently traveling at with 1500 engine RPM then to me it would appear that all is as was originally designed as the prop etc. seems to be matched for these figures.
1500 RPM should make the unit economical.
An actual measurement of the current rack setting and a check in a current Rack Setting Book for your engine would tell us what HP the engine is capable of at the current 1500 RPM.
It could be that the engine is capable of more HP than your vessel requires to travel at 8.5 knots which tells us that the entire drive train has been set up correctly in the first instance--I stand to be corrected.
If the vessel and engine have lasted all this time without undue stress whilst traveling at its designed speed then I would leave well alone--as I said earlier our model trials at the Cat School showed there is nothing to be gained adding more HP to a vessel already traveling at its optimum hull speed except increased fuel consumption and decreased engine and drive train life.
Prop design is a smoke and mirrors scientific field all of its own we were told, and so we did little except to use 12 volt electric motor powered model boats with varying hull shapes and interchangeable pitched diameter and number of bladed props to see the effect of over pitching or under pitching the prop had on engine RPM and amperage draw(load) to tell us what the end net result was. This gave us a view into the murky world of prop design.
Somehow I have ended up with a prop slide rule calculator for props but have no idea how to use it.
The scan below shows the High Idle adjustment screw--if you wish to try and screw the screw out one half a turn to increase the engine RPM as an experiment and see what happens in regards to your hull speed and engine emitting black smoke (wasted fuel) due to being overloaded.
Mark the hex screw head so you can return it to the previous correct position--I did this for a few clients to convince and so prove to them that there was nothing left in their engine except the ability to make black smoke, especially if I upped the rack setting too. Both duly reset to previous set positions.
Scans below show the red arrowed High Idle screw and the cover which it is under.
There is a double hex hole in the rear cover for holding the adjuster screws in their adjusted place.
Be sure to align the semi-circular cutout on the Rack Collar with the aligning pin in said rear cover when you refit it.--There should also be a torque spring group in there that is not shown in the sectional views--be careful not to distort the blade spring with the small adjuster screw thread in said disc when handling things.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
