- Thank you received: 187
Here is a photo from 2011 of my D4 7J tranny, you can see the difference in the thickness between the left steering clutch pack and right steering clutch pack, when you use the brake drums as a reference point. The older gentleman is one of the best self taught Cat Mechanics in Australia, he lives 2,000 miles north of me in the land of mango's, and kindly visited and helped me put the D4 tranny back together, I wouldn't have gotten it done without his expert guidance.
Both clutches were dismantled, cleaned and re-assembled with new bearings and seals, plus we fitted a replacement crown wheel, and gear shaft with pinion, plus all new gearbox bearings, and final drive pinion bearings, plus new brakes, replaced the bellhousing, a few years later, around 2016, fully rebuilt the pilot motor with the expert help of "Edb", then pulled the diesel motor liners and reconditioned the head fitting new valves and rings, finally got the tractor back together and driving just over a month ago.
So there you go Mangoman, bought the busted D4 in 2009, got her running around 2012 but only briefly, wasn't till 2020, and after spending at least $7,000 or $8,000 on top of the buying price, that I got to really give her a good workout, try and avoid following in my footsteps.
Mike
The lift links should be 8 1/2" center to center.
Your welcome!Thanks Rome!
The D4 7J tranny is very similar to the D4 7U, they share many parts, and ten years ago when I was working on mine, prices for Cat bearings were not too bad, expensive compared to common bearings, but not out of the ball park, but it seems the past 5 years prices have doubled, in some cases tripled for the same part, even simple items like nuts, bolts and spring washers have gone up big time.
Cat make the best parts, including their basic nuts, bolts and washers, and they used to be cheap for what you got, but not anymore, and even used parts like gears can cost a lot of money to not just buy, but to freight too, and finding someone willing to sell the parts can take a long time, a lot of dead Cats have gone to China as scrap the past 10 years, so it's harder to find one getting dismantled.
If you have rebuilt a Landcruiser and done a home reno then you are handy with tools, just don't make work for yourself is all I'm saying, and when you put the tranny top back on that tractor, make sure you put a good lube on all the bolts and nuts, so if you need to open her up again you will get it done in a third the time it took the first go.
Just out of curiosity, have you driven this old girl much yet, were there any obvious issues?
Mike
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
