- Thank you received: 0
My d4 7u seems to not have a main clutch lock, I don't know if I'm not doing it right or maybe it was removed but I can't let go of the clutch lever without it disengaging. The transmission group no. is 5h134 (low speed group I believe) if that helps.
Thank You
Josh
You're right the snap was quite satisfying, I was able to find the procedure in my manual just as you described, loosen the nut the adjust accordingly. Was not fun to access inside the cover as I am not small person and the machine has a logging cage on it, was able to do though after unpinning the main clutch lever and bungee cording the steering clutch levers back.
Thanks for all the help
Josh
My D5 has the similar issue. I adjusted on it for days and never got a snap. I'd love to know the satisfaction of that handle staying engaged.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
