- Thank you received: 55
So this is how this form works someone asked a legitimate question people with knowledge try to help troubleshoot and answer questions. Then you have someone that doesn’t even know what a 46 a machine is and they gladly give their opinion it just confuses everything why? No response Necessary thank you.
The series tractor you have has a diesel 3 stage converter followed by a 3 speed powershift transmission. I suggest that you lift the floor plates so that you can watch the driveshaft between the converter and the transmission. If when in gear under full revs the shaft comes to a stop when held with the brakes then that transmission clutch is ok, so systematically go through the gears and forward and reverse to identify if you have slipping transmission clutches or a torque converter problem. This is the most basic test for troubleshooting the issues you are having, will narrow the window of what could be the problem. The transmission only has 5 clutches, 3 speed clutches and forward and reverse clutches.
Wombat
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
