d8h no pushing power
4 years 4 months ago #216820
by chadm
Hello all, I have had a d8h cable dozer for a couple years for farm use with no issues, but now the machine will not push, actually will hardly even drive at all. Engine runs good and powershift transmission is good. I dont know much about these machines otherwise. Why do I not have any power to push? Is there a clutch that is gone or in need of adjustment? Is it the torque converter? Thanks in advance.
Thank you received: 46
4 years 4 months ago #216821
by dpendzic
have you checked the transmission/torque converter and steering clutch oil levels? are the fuel filters clean and the tank vent open?
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
4 years 4 months ago #216822
by chadm
Transmission oil level is good, torque converter appears to source its oil from the engine? How do I check the steering clutch oil level? When I bought this machine unfortunately no manuals came with it. Everything appears good on the fuel side. Thanks
4 years 4 months ago #216826
by dpendzic
you should really go on ebay and get the manuals for your machine---at least maintenance and operation
Thank you received: 142
Thank you received: 341
4 years 4 months ago #216844
by edb
Hi,
please help us out as the answer we give depends on your S/No, early D8H's from 46A1 to 46A3043 units have a 3 stage diesel fuel operated T/C and later D8H's have a single stage transmission oil system driven T/C unit fitted.
As you can see we can easily give you incorrect advice. Cat machine Service and Parts advice always requires a S/No to be given as continual upgrades were applied to machines with a cutoff S/No and a start S/No for a new upgraded unit.
Regards,
Thank you received: 49
4 years 4 months ago #216888
by chadm
I can get some fuel filters tomorrow if you think they could be the problem. The engine runs good and throttles up as it should, or can the filters be affecting something else I am unaware of? The cat can turn right and left, 1st gear works pretty good if you're not pushing, 2nd and 3rd are a struggle as it seems something is slipping and not transferring power to the transmission. Thanks
Time to create page: 0.182 seconds
