What are the symptoms of a failing condenser?
4 years 4 months ago #216739 by Bill Glenn
What are the symptoms of a failing condenser? The pony motor on the 955 12H has been missing worse & worse… Just wondering if the condenser could be the culprit. Also, here is a picture of Rodger the Dachshund & I getting ready to skid some firewood on said machine.
4 years 4 months ago #216740 by Norm R2,22
Usually the engine will run rough, if at all. Back firing as un-burned fuel from the mis-fires in the exhaust catch. Most people suspect carburetor problems. Thus the saying, "90% of carburetor problems are electrical".
4 years 4 months ago #216743 by neil
They also might start ok cold then as they heat up become less reliable, and so "won't start when hot". Might also get a yellowish spark instead of a bright blue spark.
4 years 4 months ago #216755 by Mike Meyer
Do they burn the points too?
4 years 4 months ago #216764 by Bill Glenn
I have a white spark now... what does that mean...?
4 years 4 months ago #216765 by Bill Glenn
I have a white spark now - what does that mean?
4 years 4 months ago #216767 by Bill Glenn
Where can I get said condenser?
4 years 4 months ago #216772 by Rome K/G
Cat should have it. Have a part #?
4 years 4 months ago #216774 by ccjersey
Caterpillar should have it or any of the magneto shops can get them if they don’t have it in stock. You can also test with a multimeter to see if they’re shorted or open. I think most ignition capacitors are about 0.3 microfarads.
Before I took the condenser out I would clean the points with an emery board and re check the gap. That takes very little time and can fix problems immediately.........or not and then you move on to something else.
4 years 4 months ago #216777 by kittyman1
Replied by kittyman1 on topic yes exactly !
yes this has been my experience exactly....after a few minutes it starts missing...acting crazy...maybe even quitting...and no start...:tape:
-almost exactly the same as some electronic modules...
