212 wheel cylinder #
4 years 5 months ago #216036
by D. Jones
Lost a wheel cylinder on a Cat 212 grader that belongs to a non-profit group that I turn wrenches and operate for as a volunteer.
I called the local Cat dealer and they want $151.00 each for wheel cylinders. I've was told by the heavy equipment mechanic, that we use when we need special tools etc, that a replacement is available through NAPA but he doesn't have the part #. I called NAPA and they can't cross the Cat number to their system. Has anyone here used after market wheel cylinders for their Cat grader? If so do you have a part # NAPA can cross check? The old Cat part # is 6B2715 the latest # is 8D4074.
I'm hoping that I can get new cylinders and have them on hand so the mechanic will only have to make one trip, that is if no other problems are found, as a one day costs over $800.00. I don't have the hydraulic puller needed to remove and replace the brake drums so must use the mechanic.
Thank you received: 9
4 years 5 months ago #216050
by ccjersey
Sorry I don’t have the numbers, but once you get it off you can take it in and match it up........usually. Caterpillar used off the shelf hydraulic brake components in everything I’ve ever worked on. Most of it has been Wagner I think. You may well find that a quick hone and some new cups will get it going. More likely to have one of those kits than a whole cylinder.
For those prices I think I would investigate purchasing hydraulic tooling! I actually made a fixture to use a couple 20 ton hydraulic jacks to press the hub back on since I didn’t have a hollow ram cylinder big enough for the 40 tons DRY CLEAN press fit.
I borrowed a big T bar type puller to remove it. Guy I borrowed it from said to tighten it up and then smack the forcing screw head with a sledge hammer and it would pop off and he was exactly right. You can’t leave the round spindle cover nut on but as I remember the whole tire, wheel and hub didn’t go flying or anything. My rims were stuck to the hubs really bad, so after the first one, if I didn’t have to take one off the hub I didn’t.
Thank you received: 31
4 years 5 months ago #216052
by oldbeek
I have heard of guys using a puller from Harbor freight. But the hubs are also supposed to be pressed back on. The nut is just a safety retainer. I used to buy them at Napa. Cant remember, 1 inch to 1 1/8 size. They have a Wagner cast # on them. Very common in the day, but drum brake parts are not so common anymore. Cat used 2 different size cylinders. 1 for 2 wheel brakes and a smaller size for 4 wheel brakes as on county owned graders for roading. The master cylinders are also Wagner.
Thank you received: 13
4 years 5 months ago #216053
by greengiant
I'm in the same situation. blew a cylinder just as I was starting out and fortunately not while I was on a steep hill.
I was excited to be able to get new cylinders from the local Cat dealer even though they are indeed pricey.
I was going to attempt a fix myself (plan
but you threw me a curve about the need for a hydraulic press to remove the drum. I had no idea and have not been able to find a shop manual. probably have to go back to plan A and have the local diesel shop fix it.
in the meantime I made it drivable by plugging off the hose on the bad cylinder.
4 years 5 months ago #216054
by D. Jones
6B4074 comes up as a spacer plate???
I hate this getting old.
The correct numbers are:
old: 6B2715
new: 8D4074
And of course I can't take one of the cylinders off until the drums are pulled. The real mechanic has the hydraulic puller but as I stated earlier he will cost us $800.00 plus for one day so I want to limit use of him to no more than one day if at all possible.
I suppose I can try to rig up some sort of a frame and jack arrangement but the biggest jack I have is only 20 ton so I'm not very confident I would be able to get them off and back on with that.
I do need to get the brakes working as I want to try to find a younger person willing to take over the operation of the grader as I don't know how much longer I'll be able to do it and I don't want to start them off with a machine with no brakes.
Thank you received: 409
4 years 5 months ago #216061
How many tons are required to pull the hubs? There are very affordable rams on the internet. I have a pump and ram from China for I want to say about 600 which I've used multiple times so cost-wise it worked out
I have a machinist that I get to make up various hubs - usually just to turn down shapes that I can use with my hollow ram, which bypasses the need for expensive adaptors, and I get my bolts etc. from Fastenal - just as many as I need and in the size I need. Quite affordable and means I'm not reliant on the mechanic getting it done with a budget
4 years 5 months ago #216076
by ccjersey
Pulling is the wild card. I had one on the grader when I bought it that had come loose and messed up both spindle and hub so I just had to be able to press the new/used hub back on the new/used spindle. That was a front spindle so no brakes behind it.
Then I jacked up the other side and could hear something loose and scraping around in there when I rolled it over. So it had to come off to even diagnose the problem. That’s when I borrowed the t bar puller. I could have welded up one once I saw what it took to get one off. The forcing screw was about 1 or 1-1/8” fine thread and as I remember the threaded holes in the hub for pulling are 5/8 coarse. I just grabbed some grade 5 nuts and all thread and it worked just fine.
If I had to build one, I would buy about 16 - 18” of grade 8 all thread and two nuts to fit. Then a piece of heavy 2” square tubing for the cross bar and the spacer. Drill two holes near the ends of the cross bar spaced apart the same distance as the holes in the cast hub. Drill another one in the center between the two for the forcing screw. Cut another piece of the square tubing to stand the braces Opoff about the same distance above the crossbar as the two small holes are apart. Then you can use 4 pieces of flat iron say 1/4x2” to brace from the nut to the ends of the cross bar.
So this thing would look like a large triangle split in equal smaller triangles by a vertical section of the same square tube with the nut at the top of the
and the 4 braces (two to each end) angling down to the ends of the crossbar.
Note, I drew this with the nut under the bottom of the cross tubing but realized later that though this would reduce the need for really good welding to attach the nut to the top of the standoff tube, it might just crush the cross ways piece of tubing.
I did some browsing on McMasterCarr and they have both 1 and 1-1/8” fine thread grade 8 in 3' sticks for about $60 and nuts are about $12 each so you would have maybe $150 in materials plus welding if you couldn’t do it yourself. I usually build this type thing for a specific job but later it gets modified for other uses by drilling holes on different spacing
Thank you received: 103
4 years 5 months ago #216077
by Fat Dan
I'm looking where I found the information. I believe it was for a 112E but works for the early style motor graders.
This is how the manual explained how to break the drum loose.
The side you want to break loose is on the ground.
I'll find the source..
@ccjersey: I see you beat me to it
ACMOC Membership
4 years 5 months ago #216080
by Fat Dan
Sadly the source is on the old computer what crashed.
I gleaned the pic back off a forum I had uploaded it to before crash.
ACMOC Membership
Time to create page: 0.184 seconds
