Quarentined to my end of the desert
Thank you received: 191
4 years 5 months ago #215054
by D4Jim
I remember an old 50 Merc I had to replace a water pump on and after wrestling with it for half a day I figured out there was one last %$#@*&?* bolt up inside the water pump before it could be removed.
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Thank you received: 31
4 years 5 months ago #215058
by oldbeek
Water pump was good for maybe 10,000 miles. Now we bitch when they go out at 200,000.
4 years 5 months ago #215061
by willitrun
Yeah, and the water pump had a flimsy cast-iron motor mount sticking out and bolted to the frame, first thing to break in a collision on the track. One time it caused the throttle to go wide open, exciting for a bit.
4 years 5 months ago #215067
Actually the 49-51 Mercury water pump/motor mount was quite stout. Much more so than the early Fords.
4 years 5 months ago #215084
by D4Jim
you're right O. M. and the distributor was lots easier to work on.
Sat right up front where the water from a mudhole would drown the sucker out!!
Back then they didn't have very good seals on the plug wires if any.
D47U 1950 #10164
Thank you received: 341
4 years 5 months ago #215115
by edb
after much struggle and bad language working on Ford V8 distributors in place in Bren Gun Carriers as a teen, it was a revelation to find they were designed to be easily removed and re-fitted and so be worked on on the bench.
Re-timing was easy due to the same offset drive tang system as Cat uses for most early Injection Pumps.
memories of days gone by and skinned knuckles--lol.
4 years 5 months ago #215386
by D4Jim
Got out today to roll some dirt with my 12. Wish I knew how to resize pics.on my I phone. Rebuilt a 1/4 mile of dirt road. Moisture content was just right. Didn't come in contact with anyone. Didn't touch anything but the controls. I live out near nowhere. This is the road to Rodgers house. He was my right hand man getting this old 12 running again.
Looks like good work and I am envious of your scarifier. Wish I had one. Picture below is my driveway I was working on with the 112 a few years back but of course less a scarifier!!
The black gizmos on the windshield are "camper levels" so I can tell when the machine is level and also angled ones to use when building terraces to get the correct slope.
Yep, quarantined here too.
D47U 1950 #10164
Time to create page: 0.197 seconds
