Pony Motor Oil Drain
Thank you received: 9
4 years 5 months ago #214988
by ccjersey
My plan is to hopefully tilt the pony like the book shows to remove and re-install the pinion. So the plan is to leave the current gasket. I bought a replacement gasket just in case, though. I'm not really sure yet how I would hoist the pony out if I did want to remove it completely.
By view of the gasket, it looks like there are 14 bolt holes.
There will be some dowel holes in that gasket too so you won’t find 14 fasteners. Just get a screwdriver, compressed air blower etc and clean all the way around on that base flange of the pony before you start.
4 years 5 months ago #214992
by BigAgCat
Yeah, I was planning to do some cleaning before doing the job. It is pretty dirty down in that area.
Cat D6 5R
Thank you received: 46
4 years 5 months ago #214998
by dpendzic
How long have you owned the machine and you never changed the pony oil before????
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
4 years 5 months ago #215000
by BigAgCat
Seeing as I was asking if a drain was for the pony motor oil, it would seem obvious I never changed the oil. I have owned the machine for under a year.
Cat D6 5R
4 years 5 months ago #215001
by dpendzic
the first thing i do when i buy a machine is change all the oils---you never know what the previous owner has done
Thank you received: 31
4 years 5 months ago #215002
by oldbeek
4 years 5 months ago #215003
by BigAgCat
That's probably a project I will do here soon. I have been gaining more knowledge of my tractor since I have had it and I still don't really know how much oil the crank case holds. It seems I may need a 5 gallon bucket or more to empty it. I will also be draining out and replacing the transmission oil too. It's unfortunate the books don't seem to mention the oil capacities so a person could more easily know how many jugs or buckets of oil to purchase.
Cat D6 5R
4 years 5 months ago #215004
by BigAgCat
About pony oil. IF The rear crank seal goes bad oil will go into the pinion area. No sign of it leaking except to much oil in the pinion area. Pony parts are getting scarce, so always, always ck your pony oil before firing it up. Keep it full. How do I know.
Yeah, I check my pony oil pretty much every time.
Cat D6 5R
4 years 5 months ago #215006
by dpendzic
my parts books for my machines usually have the oil capacities in them--last page
4 years 5 months ago #215009
by BigAgCat
Oh, I found it. 19 quarts. It was hiding in the first couple pages of my serviceman's reference book. Maybe it was the transmission oil capacity that isn't there.
Cat D6 5R
Time to create page: 0.171 seconds
