- Thank you received: 31
Sometimes a grinding starter is a result of a low battery.
Check the pony oil every time before use. The rear crankshaft seal, IF leaking goes into the Pinion area and you don't see the oil leaking. Oil level can be fine one day, then the next time you start it 2 months later, oil is gone. By, By crank. Don't ask how I know this. What serial # is your 12? Add to list;; grease the pilot bearing on the flywheel. If you cant lift the front end with the blade , you may want to remove the bull gear covers on the lift arms and turn the gears 1/3 turn. Will not kick when gears are right.
Voltage is important but more important is amps - if your jumper cables or the connection that they're making isn't adequate, then you're still constrained. If you can put a battery in it, and add jumper cables from the truck, and your existing cables in the machine are adequate, then you can rule battery capacity out. I had "regular" car size cables on my D2 with 6 volts - good starter and excellent battery. Cranked like a piece of junk. Fitted 2/0 cables with clean, bright connections - cranks like you'd hope/expect it to - same starter, same battery.
.This is also a possibility. No battery in the unit, so I'm attaching two sets of jumper cables to the lug on the starter, one from each of the batteries in my truck. Probably a little less cranking voltage than a battery under the floor, but given that this is actually a 6v starter, I bet it's getting more voltage than it was designed to operate with... I think it needs a cleaning and lube...
Good to know. I finally found the dipstick on the pony before I started it last time. It was all good. Before that, we checked it with a wire poked down through the oil fill port just be be sure something was in it.
This grader is S/N8T15562. Just a few units before the wet clutch.
It also has a scarifier with most of the teeth still present, and what I think is OE power steering. Cab with heater and almost all of the glass intact.
I'll add the throw out bearing to my list of to-do's. Operator/Maint manual should be here today, and I'm sure that will help a lot!!
I need to see why the trans shift is so sloppy too. On my old SM465, there was a roll pin that wore out in the top cover. I believe this trans shifts through a linkage, so perhaps just sloppy linkage pivots... I haven't really looked at all.
I have not tried to lift the front with the blade, but I did get decent down pressure on the blade before the dogs wanted to kick out. Will turning the bull gears help keep the dogs engaged?
Thanks for all your help!
Lots to do, but building my house comes first, so I'm just making a list that the other guys here can go through while I'm busy.
Yup. Possible that cranking amps are a bit inadequate off the jumper cables, but I'm sure the starter needs love too.
The existing positive battery cable is like 1/0, which is needed with 6v, as it takes twice the amperage when you only have half the voltage. I imagine once we get a decent battery in it, with a heavy ground cable too, I won't have to use any jumper cables. Gotta see what size 12v battery I can cram in the tiny little battery box under the floor... It's got a 12v alternator scabbed on above the 6v generator, which I'm hopeful we can get to work. It appears to be a single wire alternator, and there's an "alternator" on/off switch on the gauge panel.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
