Cat 12 8T grader starter for pony griniding
4 years 5 months ago #214613 by 1stDeuce
Greetings, I've been surfing the forum here at ACMOC for a while as I contemplate the purchase of an Cat 12 motor grader. It is 1955 vintage, made a couple hundred units before they changed to a wet clutch.
Yesterday a friend and I went over and got it running, as it had been sitting for the better part of a decade according to the seller. Both the pony and the main engine run fine and sound pretty good. One issue we noticed was that occasionally the electric start on the pony would just grind, rather than spinning the belt and pony engine over. It was trying to turn the belt a bit as it was grinding...
I've searched, but all I get are threads looking to replace the pony with electric start, or saying that the lever engaged pinion is grinding. Neither of those are what I want...
I didn't see a "bendix" on the starter, only a ford-type starter solenoid. Is there a one way clutch in there, or some sort of centrifugal engagement that's likely just gummed up? It did not sound good when it wasn't catching... Just looking for some quick feedback on this issue before I buy this grader and find out it's something major.
Once we seal the deal, I'll immediately pick up the operators manual and service manual for it, and that will probably answer my question, but buying manuals for a grader I don't yet own seems a bit foolish.
Thanks for feedback!!
Looking forward to getting this old girl out and grading again soon!
New member Chris
4 years 5 months ago #214614 by Rome K/G
You have to loosen a 5/8" lock bolt on top of the starter holding housing then slide the starter out, most likely the bendix is dry, don't grind it too much or you'll be trying to find another drive gear if it isn't to late already.
4 years 5 months ago #214615 by ccjersey
It’s an old fashioned bendix design with a spring torsional shock absorber built in. If the spring was broken I don’t think you would even get a grinding sound.
I expect taking the starter out of the mount and or just unbolting the belt pulley/driven gear assembly will expose the problem in the gear teeth not meshing up.
Should be some dead starters around with those parts if yours don’t respond to a clean up.
The starter can be hard to get out of its mount even after removing the lock bolt. Easy does it, lots of penetrating oil soaking, heating the mounting ring to expand it, tapping on the starter nose etc. It’s possible to break the mount.
4 years 5 months ago #214620 by 1stDeuce
Thanks fellas!! I did see the jam nut that holds the starter in, and this particular one is actually a tiny bit loose, as I could see the starter motor wiggle a bit when my friend hit the button. I'll yank it out and clean up the works and poke it back in. It's possible it's just slipped out some I suppose... Is it supposed to go all the way in, then tighten the set screw? I'll let y'all know what I see...
4 years 5 months ago #214624 by Rome K/G
Yes all the way in, there is a small hole in the starter housing where the set screw/bolt fits into.
4 years 5 months ago #214671 by oldbeek
If the helix twist on the shaft is dry or sticky the bendix drive will not go in and engage the driven gear before the starter is spinning full speed. This is what causes the grind noise. Dress up the drive gear and lube the helix. The torque of the initial turn of the starter is supposed to put the drive into the driven gear instantly.
4 years 5 months ago #215863 by 1stDeuce
Thanks Oldbeek!!
We got it moved to the ranch yesterday. The starter ground again a few times, but the pony now fires right off when I mess with the choke. Seems to run best with the choke lever just a little out. All the way in seems to run worse. I am assuming all the way in is choke off, but don't have my OM yet...)
I'll pull the starter out and get it working better before we try to start it again.
I did notice this time that as the pony rolls over there's a definite "clunk" that seems to be once per crankshaft rev. I saw that the flywheel can come loose and make a clunk, but it seems like that should be twice per rev.... Hopefully its not a rod bearing... It does run well once it's running, with no audible knocking over the tiny-mufflered exhaust "roar". :)
I drove it about 3 miles to the property where it'll get worked on for the next few months and found out that it also jumps out of gear when you go downhill. Luckily I was able to mash the throttle and stick it right back in gear, then drive the next half a mile holding the gear shift forward. With a marginal parking brake and no main brakes, I did not want to have to drop the land anchor on a freshly graded road... :) The main trans shift lever is REALLY loose. If you know where the gears are, you can shift, but there's no discernible H pattern left...
"To do" list is pretty long...
Put a battery in it
Fix the starter
Change both engine oils
Add brake fluid, bleed the brakes, see how fast the fluid runs out the wheel cyls
Swap around some control links/caps between the blade lift and scarifier lift -- No shims left in blade lift rods and lots of slop but lots of shims and little slop in the scarifier lift rods...
Make a new seat cushion so it stops poking me in me soft bits
Figure out what bushes can be replaced to reduce the current 1 full turn of steering slop
Put a dang muffler on it!!
Check clutch adjustment
Hook up a fuel shutoff valve of some kind for the pony. (cab mounted valve has been bypassed with a loop of rubber hose)
And finally: Go grade and see what else comes up!
We'll probably buy it two new tires a year, and get it back on 13.00-24's in a couple of years. It's currently on ancient 14.00's, and I don't see the need for bigger tires on a nice little grader.
4 years 5 months ago #215865 by neil
Choke out to run problem is easily solved. Take the carb off, drill out the lead puck in the passage that runs along the bottom of the fuel bowl, then using your fingers, run a twist drill in there to clean the gunk out. If you decide to take the bowl off the throttle body (no need to), loosen the bolts and carefully pry the bowl back along the bolts. Once it's loose, then take the bolts out and slide the bowl off in the same direction avoiding damaging the tube jet.
You'll need a gasket for the carb base and that's about it. Don't know about the grader but control is in choke off on the D2, and control out for closed throttle.
4 years 5 months ago #215893 by old-iron-habit
You'll need a gasket for the carb base and that's about it. Don't know about the grader but control is is choke off on the D2, and control out for closed throttle.
After you clean the idle passage in the bottom of the carb a .177 air rifle pellet works perfect to tap in to seal it again. Some get fancy and tap it to a small screw for future cleaning.
1937 Cat #11 tandem auto patrol,diesel, w/plow and wing, 6K506SP, 1937 RD 4 Ag Crawler RD5356, 1939 Cat 22 2F5429, 1952 Model 212 Grader 9T03427, 1953 2U D8 Dozer 2U20751, 1961 922A Rubber Tired Loader, 59A812, LeTouneau LS Cable Scraper, Cat/Lincoln 600 AMP Dual Welder, DW-21 Cat Scraper, DW-10 dump wagon/water wagon
4 years 5 months ago #215902 by BigAgCat
Sometimes a grinding starter is a result of a low battery.
Cat D6 5R
