398
398
Thank you received: 16
4 years 1 month ago #221335
by Mangoman
That is one heck of a chunk to bring home! I snuck a D4 5T home and my wife never even noticed in our small yard which has me thinking...😂 Nah better not...
I used fo work on large gas engines in my apprenticeship. Almost all of those series were NA except for one 398 that I remember that also had large air to air coolers. They were a pretty darn good engine. Not much for fault other than almost all of them leaked. I guess a few hundred thousand hours on the block and numerous overhauls will do that. One 398 we overhauled needed a cam and we had to wait I think more than a month for it to weave it's way from Singapore I believe. There were running on net gas of varying degrees of quality but they all seemed to do pretty good. Not the burned valves of the smaller 3400 series engines. When we went to service those, we packed a head and associated gaskets. They did not hold up at all in my experience. They burned valves constantly and generally suffered much shorter life with cylinder and ring wear in general. Now, the 3500 series, that was an engine! Amazing run time with those. Once in a while we may replace a head and they eventually all wear out, but they are a great engine.
Also I remember when BCIT took over the old Finning (Cat dealer) facility down on Great Norrhern Way in Vancouver, they left a D398 gen set they had for standby power. It had not run in many years and when our class fired it up, we ran the fuel return into 20L pails. Well there was alot of muck that came out of there! Might want to consider that.
I often got the heebie jeebies when working on gen sets after a big job. I had one recip compressor come apart when we put a load to it so I am still a little gun shy. Is there any reason one couldn't disconnect the throttle linkage and "play God" sort of speak? Generator not online of course.
Thank you received: 19
4 years 1 month ago #221336
by 1951D2
This is after having it running a couple of times. It has cleaned up real good , now will have to get a load on it and all should be good.
Thank you received: 48
4 years 1 month ago #221339
by mog5858
wow your sure do some nice work. looks like you got her dialed in it sounded good when it started. keep up the good work
Thank you received: 43
3 years 11 months ago #222671
by 1951D2
Just trying to see if I can post or not in this thread or to see if it is just me with poor computer skills.
3 years 11 months ago #222672
by 1951D2
Ok, I think I figured out my issue. I was trying to go right to the box and start typing ........... wrong , I had to hit the action box first pick one of the three choices and then go and type in the big box. Whew.......... I will get this figured out yet. Just so you guys and gals know ,I am a lot better at stuff with grease on my hands.
ag-mike
2 years 10 months ago - 2 years 10 months ago #232361
by 1951D2
Took the engine out to WMSTR,(ROLLAG), I have videos that I am trying to make work but at the time it says they are to big. I did run it across the scale on the way. 22250 lbs. engine only
1951D2.
2 years 10 months ago - 2 years 10 months ago #232369
by 1951D2
Here it is running at home after getting the governor adjuster. I did eventually get the Woodward set to 600RPMs cause that is what I run my blade at on the sawmill.
1951D2.
2 years 10 months ago #232370
by 1951D2
This was the spot I had to dig out so the drive shaft wasn't at to much of an angle
edb,
Haus
398
Time to create page: 0.186 seconds
