Stuck In Hawaii D9G Still Wont start!!! Bad Injection Pump????
Thank you received: 620
4 years 5 months ago #216017
by Rome K/G
"Oh boy.... where has this fella been? Ah Sir...we got that all investigated, figured out all wrapped up, thank you sir."
Thank you received: 67
4 years 5 months ago #216021
by kittyman1
hard to say Rome...he could be busy attacking the jungle:clap2:
Thank you received: 31
4 years 5 months ago #216022
by oldbeek
Has" George" set a record for the most questions and answers to any single post? LOL
Thank you received: 13
4 years 5 months ago #216023
by daron
Mike McWilliams (OilSlick) passed a thousand posts in the HOD8 thread on the old ACME site.
Daron
Thank you received: 5
4 years 4 months ago #216363
by gvanhouten
Daron
Hi Guys been a little crazy in this world you know..... I have been busy doing family stuff and yanked all the ripper actuators out and got the parts from Cat for the kits....
Got the nuts to be replaced as well and I have got a question for Old Magnet or anyone else...
So I have the lift cylinders installed with new seals/nuts and even put wiper seals in with bearing mount adhesive..
I noticed when taking apart the cylinders that some have washers and some don't... The lift cylinder has them but the tilt cylinders do not have any washers that buffer the nut and then behind the first segment of the rod... The rod takes a 4 " nut part #46j888...
The part number for the seal kit for the tilt cylinders are Cat part #245-6827
I need to install the washers as my OCD does not allow to skip it and put it back without them.... If someone could please give me the part #for the lift cylinder washers I would be appreciative... Old Magnet???
4 years 4 months ago #216380
Seems as it should be:
Tilt cylinders do not have washers under the nut, just a 4J6898 washer on rod side of piston.
Lift cylinders have 7J2094 washers on both sides of the piston
4 years 4 months ago #216383
by gvanhouten
Tilt cylinders do not have washers under the nut, just a 4J6868 washer on rod side of piston.
Thanks Old Magnet you are the best..... On the tilt cylinders there is nothing so I will order them....thank you for your help and I will install on the rod side of piston....
4 years 4 months ago #216386
by gvanhouten
Hey Rome!!! I have been a little busy and did not really do much with the D9 as she has sat waiting on some parts for the ripper and the rocker box gaskets ect....
I think everyone would be proud.... I walked away from a D8K that was needing a ton of work and I didn't bite.... Valve covers was rusted through on 123 piston and was very corrosive... Needs all new undercarriage.... Guy was asking 3k. but it would be a ton to bring her back to life.... Different setup with the Ip and all... Pretty small next to my 9... My next step after I get all the ripper cylinders back and repacked and do the rocker box gaskets and all is to give her a paint job..... After seeing the 8 in such bad shape I dont want my 9 getting roughed up in the Hawaii sun now that it is out of the Jungle... Hope everyone is well.....
4 years 4 months ago #216390
by Rome K/G
Hey! glad things are going good. Sounds like a good choice on the 8. The cylinders can be allot of work!
4 years 4 months ago #216584
by gvanhouten
Okay, today I am taking off the rocker boxes to replace the gaskets underneath.... When looking at it it appears I am going to have to re-adjust all the valves. So am I correct in the fact that the valves will need to be re-adjusted... That really stinks because I will more then likely I have to take the starter out again and put my engine tool to spin the flywheel correctly.... It is a PIA>>>>>. To say the least.... I have the manual and will look in there but want someone who has done this before... Let me know and thanks as always.... I will tell you what I find with the existing gasket if any at all from the looks of it I don't see it.... In addition I cleaned the engine before disassembly....
Time to create page: 0.427 seconds
