D4 #44 hydraulic question rear remote
Thank you received: 142
6 years 5 months ago #182165
by bursitis
on my D4 6U with the 4S blade there is a hydraulic distribution block on the right front fender. this block has a lever and a set of blanked off ports so i figure it's purpose is as a selector valve to disable the blade and redirect the flow to another place like a rear attachment. not as handy as a double valve set up but should be workable as a farm cat. what i am thinking is try to find a set of compatible flanges to bolt to the diverter valve and run a set of hoses down the fender to the rear of the machine and weld a couple of chain hooks on both side of the cylinder brackets under the blade lift cylinders as positive stops to hold the blade while using the rear remotes. so a couple of questions are in order. where can i source the flanges and do you think this is doable?
Thanks John
6 years 5 months ago #182223
You can make your own flanges. Flanges are flat faced, the o-ring seal provision is machined into the cross-over valve.
Thank you received: 183
6 years 5 months ago #182276
by d2gary
I have a similar set up on my 5T and the plate is 5/16 or 3/8 plate with 3/4 pipe nipples welded in. Should be pretty straightforward to build some
6 years 5 months ago #182312
by Chuck C
A well stocked hydraulic shop should have them or could get them. That is were I got mine.
Chuck C
6 years 5 months ago #182330
by Vance Nickerson
I too have the valve and handle but I have two control levers what's up with that? I do intend on pulling a disc around the pasture if I ever get this thing running.
6 years 5 months ago #182331
by Chuck C
Vance I think you have a 2 valve 44 unit. The left lever is for the blade and the right lever is for the rear remote.
Chuck C
6 years 5 months ago #182332
by STEPHEN
Chuck C
There are still only two pipes from the pump, so the diverter valve will have to be used to switch from blade to rear. I don't know where the other spool goes, could be on the left side
Thank you received: 409
6 years 5 months ago #182333
Vance,
look on the top of your hydraulic control at the front of the tractor. There are four pipe outlets, two of which are used by the pipes on the right side of the tractor as seen in the photo. The other two outlets may have blanking covers on them with two bolts each. If you were to remove those two blanking covers and fit up some pipes to the rear of the tractor, you could use your second valve to control trailed equipment independently of the blade valve, assuming that the control has the second valve components installed (they should be since you have the external levers etc.).
