- Thank you received: 0
this is front mounted unit for lifting blade.since i posted this i've looked it over again and i'm thinking i need to adjust lever by seat since blade won't dropIs this for a front or rear CCU?
If the brake band is loose, away from drum, there is something else wrong. Have you adjusted the clutch discs to tight(the adjustment in the center of the unit)?this is front mounted unit for lifting blade.since i posted this i've looked it over again and i'm thinking i need to adjust lever by seat since blade won't drop
even brake band is loosened.there is a threaded bolt with spring attached to it and i may have tightened that too much ,thus not enough free travel in
handle by seat for it to drop.
if you wouldn't e-mail a phone number. i'm a slow typer and prefer talking on phone.
thanks
larry lynch
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
