D-2 & 15 share same tracks?
17 years 3 months ago #6936
by wide track
Does D-2 have same tracks & rear sprockets? Both being small Thought mite work? Where can find new ?
Thank you received: 37
17 years 3 months ago #6943
by naylorbros
Someone will correct me if I am wrong so here is my answer. The tracks will interchange between the Fifteen (PV series), Small Twenty ( 8C series), the Twenty Twos and the D2's, depending on how wide the pad is. There are differences in the link designs, counter bored links vs. non counter bored links and master pin styles. The sprockets will interchange between the late Twenty Twos and the D2's. The difference in the sprockets between the PV Fifteens, 8C Twentys and the early Twenty Two's and the late Twenty Twos' and the D2's is that the early tractors had the sprocket keyed to the sprocket shaft and the late tractors had the sprocket splined to the sprocket shaft.
Have a great day!!
Ken
Thank you received: 20
17 years 3 months ago #6954
by 8C 361
I was never too sure about this but I think Nalorbros nailed it. I am pretty sure the D2 is 6 1/8" pitch. I just went out and measured the 8C 20 and it seems to be the same.
Thank you received: 9
17 years 3 months ago #6980
by ccjersey
D2 is 6.125" pitch and 3.00" height new.
I don't know about the width etc between the different links, but you maybe could get by with some difference there if the sprockets, track rollers etc have some wear.
Need to find something that fits that's available, not something that's no longer in production:D, but I guess "available" is a relative term.
good luck!
