Early D2 master pin plug removal tools
17 years 3 months ago #6765
by Sargosailor
I just received from Cat pn's 2B2108 Sleeve, 3B1027 Screw and 3B1028 Nut.
These tools are listed in the D2 Servicemen's reference book as required to pull the tapered plugs in the master pins. However, the screw and nut are 1/2" NF. The plugs are tapped 5/16" NF. So far no one at the Cat dealer can explain what happened. Anyone on this board run into this? How did you pull the plugs?
Jim
Thank you received: 34
17 years 3 months ago #6766
by Steve A
I used a 7/16 NF grade 8 bolt and a 1/2 inch socket that would fit over the pin, add washers as needed to keep from bottoming out but be sure to mantain enough of a bite to avoid stripping the threads on the bolt. I sugest start with 4 threads engaged, run a tap through the plug to begin with, blow out with compressed air then lube the threads with oil or grease. Good Luck
17 years 3 months ago #6767
I see what you mean in the D2 Servicemen's Reference Book. Cat screws up again:rolleyes:
Those are the parts required for the D4/D6 with 1/2 in. NF threads.
The parts you need for the D2 are 7B2708 screw, 7B2709 sleeve and 7B2710 nut.
Check your threads again....I believe these are 3/8 NF. I don't think you could pull anything with 5/16.
Thank you received: 10
17 years 3 months ago #6770
by bcwayne
Old Magnet is right... they are 3/8" fine threads on the D-2. I also bought the Cat tool to do the job, and proceeded to break it...Cat would not replace it. I have had much better luck using a slide hammer to remove the plugs. Good luck.
17 years 3 months ago #6771
Thanks bcwayne, I thought it was 3/8 but I'm a little rusty on the D2's.
For the 4's and 6's I use a combo for the tough ones. It's a long (5 in. I think) continuous threaded grade 8 bolt that I preload with socket and nut/washer with the bolt head captured in a 3000# drilled pipe cap connected to a 3/4 in schedule 80 pipe with at least a 10lb slide hammer weight. (sometimes use an old cluster gear that's probably about 20-25lbs). I tighten the nut as tight as I dare (with full thread purchase) then give it a whack with the slide hammer, also a little heat if I think it needs it. Haven't had one yet that couldn't be persuaded.
17 years 3 months ago #6787
by Sargosailor
BC & OM,
Thanks again for the help and suggestions. I did run a tap into the treads a couple of weeks ago but I can't remember sh*t any more
. I'll do it again today. I also had thought of using a slide hammer but where do I find grade 8 hardware? Is that the toughest available? I suppose Snap-on may have a hammer, they have a large facility here in Conway, AR.
Best regards,
Jim
17 years 3 months ago #6793
I buy most of my hardware on line from
www.mcmaster.com
. Going to town for anything in my area is a waste of time. Grade 8 is the toughest commercially available hardware but there are specialty items for grade 9 or better. Decent slide hammers are kind of pricey and they are not that difficult to make.
Thank you received: 6
17 years 3 months ago #6794
by ETD66SS
www.mcmaster.com
McMaster Carr is great...
Being a Mechanical Engineer, every company I've worked for has used this place.
I use it personally as well. I can order whatever I want before noon, and have it the next day...
The only thing McM-Carr is not good for it hand tools, usually the prices are way overboard...
17 years 3 months ago #6795
by SJ
Cat bolts std. & SAE are all grade 8 bolts so just figure out the length you need & I can give you the part number or just go to your dealer. They are listed by sizes in their Safe Source book and grade.Don,t just go to your local hardware store for them.
