- Thank you received: 504
Check my memory here...but I seem to recall when you bought the machine track wear was measured/estimated by measuring track links on the ground not as recommended by the stretched chain method which edb is also referring to.
Could be the chains are more than 50% worn. Keep in mind this is also average wear and it is possible to have some joints worn more than others. If it is a fluke thing you might consider replacing that one joint, possibly with another master pin and bushing but........adding new parts in with the old has its complications also. My guess on turning and segments would be $3-$5K but a guess is all it is.
As far as the UC, there was a guy from Ohio CAT that inspected the UC, but the links are Berco, and the guy was using his CAT book for the %worn numbers. And he was pulling numbers from the extended height CAT links, which these are not. Also the guy came up with a measurement of 810mm (31.88) for the internal pin wear, then he said they were 80% worn... Uhm, 810mm would be better than 0% worn. I was very confused by his inspection…
So Dan and I went through the measurements ourselves.
Link height = 4.68" 40-45% worn.
Across 5 pins = 32.31" 60-65% worn. (only problem is now that I think of it is we were measuring on the bottom of the track, we did not have the track stretched out on the top pulling the pins to their extent of the wear, but I’m no expert, and I saw the CAT guy measure them at the bottom too)
We did not measure external pin wear, but the CAT tech had 2.56" and said they were 90% worn... I didn't understand that either. They certainly looked way better than the D6C 76A I looked at last SAT, and those checked out at 65% worn.
Shoes: they are brand new.
Idlers: 30% worn.
Carrier rollers: ranging from 20-35% worn.
Track rollers: ranges from 30-50% worn.
Measurement should be for 4-links over five pins.
D6C pitch new is 8.00 in
50% worn @ 32.37
80% worn @ 32.59
100% worn @ 32.87
Rail height new is 4.78 in
50% worn @ 4.60
75% worn @ 4.48
I don't have any specs on bushing diameters.
I don't think the amount of backing up you are doing is all that excessive and no worse than constantly turning to be going forward.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
