Hydraulics for Cat 22
17 years 3 months ago #6591
by TerryinNorCal
Hi all.... seems a while back I remember someone using a power steering pump? mounted up front of a Cat 22, powered via the fan belt system, or crank pulley. Was I dreaming on this? If not, can someone remind me of what they used, and how they hooked it up? Many thanks ahead of time. Terry
P.S. Photos would help, but not necessary.
17 years 3 months ago #6593
by Cat Spotter
Hi Terry - I used a 12 GPM hydraulic pump run off the fan belt when I shopbuilt my 3-point hitch conversion many years ago. The mounting bracket doesn't show in the photo, but it's vertical and I fabbed it out of 1/4" plate with slotted bolt holes on the bottom for belt tensioning. - Richard
17 years 3 months ago #6604
by TerryinNorCal
Thanks CatSpotter for your input. What did the pump come off of to have the proper width pulley for the belt?
17 years 3 months ago #6663
by Cat Spotter
Terry - I bought the pump (not a power steering pump) new from Surplus Center and dredged up the "B" width pulley from my scrap pile.
If you wind up deciding to use a fan-belt driven pump, give me a holler and I can send you photos of my pump mounting bracket. Somewhere I have some old B&W photos of the entire hitch fabrication process. - Richard
17 years 3 months ago #6777
by TerryinNorCal
thanks for the info again CatSpotter. I apologize for the delay here, as I was up on my ranch rootin' stumps for a new road.
17 years 3 months ago #6784
by Soapy
Terry,
One of my friends removed a pto driven pump from his 22 when he restored it. If you are interested, I will ask if it is for sale, and how much.
Ed
17 years 3 months ago #6811
by TerryinNorCal
Thanks for the offer Soapy, but there is no PTO drive off the back of this machine, so I was trying to find an alternate method to run a hydraulic cylinder on a disc unit.
17 years 3 months ago #6965
by Toolbox
My 22 runs a mounted pump on the accessory drive on the right hand side of the engine under the governor and magneto mount. Its got two bolts that hold it on. The gear stayed in the engine and the pump pulled out with the key in the shaft. Just going off memory. Its been 5 or 6 years since I pulled the engine out of it to repair the throwout bearing.
Time to create page: 0.166 seconds
