adjusting tracks on d4 6u
12 years 10 months ago #64815
by callan
Hi guys,
i need to adjust the RHS track of my D4
i assume by looking at it that the large thread and nut is adusted tup the tension, however, when i look at the spring, it already look fairly compressed which doesnt make sense.
either something could be seized or is ther lock nuts or something i must undo first ?
thanks.
12 years 10 months ago #64831
by Old Cats
I may not be following what you are saying but I think you want to adjust the nut that is right behind the idler arm not the one that tensions the spring. I don't remember locks, I think it is a split nut and quite hard to move even with wedges to help spread it. I will look at mine and reply unless the more knowledable guys chime in beforehand with the answers.
Old Cats
12 years 10 months ago #64838
by ol Grump
Old Cats has it right. .the nut you want to adjust is the one at the rear of the idler yoke, not the one at the front of the spring. To tighten the track, loosen the pinch bolts first and then start working on the adjusting nut. Depending on how rusted up everything is, you might even have to use some heat and lots of loose juice to get things moving. And don't forget a loong cheater pipe that will fit the wrench. .you're gonna need it
12 years 10 months ago #64840
by Rennix
Wow, after reading all of this, I just can't wait to start adjusting mine. Luckily only my right side needs tightening.
1953 D4 6U8588 Cat hyd. blade, Hyster D4 winch
1959 955 Traxcavator 12A6595
1959 Rogers/Phelan 25 ton lowboy
1960 D7 17A14922
Thank you received: 279
4 years 3 months ago #219285
by Deas Plant.
Hi, jnick9900.
You need to turn the nut immediately behind the pinch bolts. That nut has a round section which extends through the pinch bolts. The pinch bolts clamp down on this round section which has slits in it to allow the pinch bolts to clamp it down on the thread.
Thank you received: 191
4 years 3 months ago #219291
by D4Jim
This is from the D4 Tractor manual. It makes the job much easier if you wear a white lab coat.
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Time to create page: 0.152 seconds
