- Thank you received: 6
Check your engine parts book, the seal should be shown with the flywheel housing. The plate is the housing that holds the bushing for the drive gear and is pressure lubed from some place likely the engine oil galley. If it's engine oil lubed there will be an adapter on the crank infront of the flywheel with a drive gear in it. If it's engine oil the leaking oil should be black. If it looks clean not black it will be trans oil.
The Hyd control is the name given the Hyd tank inc valves inside, the pump and control levers.
Later Bob.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
