- Thank you received: 0
That was a 1 ton Studebaker with an Olds V-8 engine! Lots of power to pull around heavy equipment. Empty, I used to blow off Fords and Chevys who would pull up at a stop sign and challenge the frumpy looking Studebaker!Looks like your dad might have been a Studebaker man! My grandfather would use nothing else on his farm in the 40's and 50's, even though he had to drive 40 miles past the Chevy and Ford dealers to get them worked on.
Thanks EddieHi drarv,
hope this helps you out, this is for the L--PL S/No units.
Thanks again. I was able to print out your re-scan and could read it just fine. Also, EQUIPDRIVER typed the instructions out in his message. Thanks to him too.Hi drarv,
try this re-scan, hope it comes through better for future reference.
KenThe big Twentys, S and PS Thirtys, and the Sixtys all used the same type of final drive seals. The outer end of the sprocket hud is sealed with a spring loaded cork, and as far as I know is non adjustable. The inner seal is a packing like a water pump packing except with a much heavier cross section, this seal is adjustable. If I can remember when I get home tonight I will get the adjustment instructions for both the sprocket hub bearings and the seal and post them in Thursday morning. I should have ask what the serial number was because there were two or three different types of final drive seals used on the big Twentys. The bellow seals were added at the start of the Twenty Fives.
Ken
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
