- Thank you received: 0
Forcus, if you have a digital camera, we'd all like a look at your project from time-to-time. We don't see enough graders on this site, and an old Auto Patrol restoration would be just the thing to watch! Good luck getting it home. GWH
Hello, I have 2 auto patrols like yours. Mine are both 1931 models. The 31's were painted grey and were just called Auto Patrol, no number 9 until late 31. Mine are serial number 8A-163, and 8A-171. The flywheel will most likely not have a ring gear, as electric start was a rare option. If you want electric start you will most likely have to custom make the parts as they would be hard to find. The starter hole is actually a inspection hole for the timing marks on the flywheel. If your mag is timed right you will have no problems with the engine kicking back on the starting crank. Having a crank start is half the fun of old cats! My graders are not running yet, as I have too many projects. They are fun to run though. They are nicknamed "rattlesticks" or "Knucklebusters" as the control levers rattle and snap when you operate them. Good luck with your project. Caterpillarman
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
