Sprockets Latest Project
17 years 5 months ago #4550
by MARTYN WILLIAMS
This is the 1944 Cat D8R at the start of its restoration, also a picture of Karl's lifting device.This is a ex military tractor with good running gear but the engine will need a rebuild due to water in the cylinders.Tc tractors will be helping with part of the restoration.Lets hope he does not nobble Karl like he did to Mr Moggeridge!!!
Hope to post photos as the restoration develops.
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
17 years 5 months ago #4552
by tctractors
This latest project of sprokets looks a cracker Martyn , the cylinder head tool required to whip out the precombustion chambers is CAT P/No 1F479 , this tool I cannot find yet , but all this tool is, is a hexagon so an allen key would do the trick, or a piece of hex bar , if sprocket could find out the size required I am sure I can turn up the correct piece, I know on the very early engines this was not threaded into the head, it was hit in place then clamped down,
tctractors
17 years 5 months ago #4555
by MARTYN WILLIAMS
I made up one for a D2,D8 is bigger,will ask Finning if they can lend one to us.
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
17 years 5 months ago #4724
by MARTYN WILLIAMS
Hello Sprocket,I am back from euro Disney now but I am on nights for the next 6 shifts.Did the combustion tool work? will ring Thursday.
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
17 years 5 months ago #4749
by Old 3T lover
Dang, I not to long ago gave away the 'CAT' tool for removing the precups.
But for years I used a home made rig. Made it from a large bolt with 2 nuts (right size to fit into precups) screwed on it and welded to bolt.
Time to create page: 0.149 seconds
