Workbench Plans
Workbench Plans
Thank you received: 46
17 years 5 months ago #4557
by dpendzic
Delta KJ--if you are going to have a 3 x 7 bench i would suggest a leg at midspan---the bending moment on your 4x4 supports is pl/4--so at a 7 ft span for say a 1000# load the bending moment would be 7' x 12" x 1000/4=21000" lbs. The section modulus of a 4 x 4--assuming dressed lumber would be 3.5 x 3.5 x 3.5/6=7.14 in cube
the bending stress would then be 21000/7.14=2941 psi-
--you really don't want to go higher than about 1500 psi for bending stress on timber.
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
Thank you received: 45
17 years 5 months ago #4558
by side-seat
24x72x1-1/2''thick plate 3'' tube legs with shelves lenghtwise to slide my many press brake dies into and a big 6'' vice on one end hyd. punch on the other. I est it weighs around 3500-4000 lbs Works great for banging on what ever and back up to hold a jig while bucking 5/8'' rivits. One of my buddies has a bench ~4''thk 3'x6' we used it as a deadman while setting his 50w'x20'h steel roof trusses on his shop.
17 years 5 months ago #4559
by SJ
Depen. The one I mentioned that was 10 ft. long at the shop did have center 4"X 4" posts same as the ends with cross supports & yes they are really needed for HD work like tractor repairs etc. If it,s just for wood working or the like then such a HD bench is not necessary & just a 3/4" plywood top is all that,s needed for wood working & maybe just 2"X 4" legs is heavy enough for that bench. Out in the main shop also where I worked had a real HD one that was about 14ft.long with a steel top over the wood top & had a big vice bolted to it.You needed the fork lift to even move it at all.
17 years 5 months ago #4560
by dpendzic
SJ--i agree with you that for wood working a lighter bench would work---even 2x4 legs will hold about 1200 lbs before they start a buckling failure. the cross supports to the legs resist buckling and a safe value to use for compression perpindicular to grain is about 300 psi so 300 x 1.5 x 3.5 = 1575#
this is for say SPF lumber---certain hardwoods go to much higher allowables.
The south american hardwoods are unbelievable in their strength.
Workbench Plans
Time to create page: 0.136 seconds
