Ross, Look on the boom's and stick's. There is a welded plate or maybe just some Cat Part# stamped there followed by a change (- #). Get those ###'s and post them here and I will check the pin Dia's. I think you would be best to weld up and line bore your boom and stick if it's only a repair you are doing not different lengths you need.
Later Bob
