Bill Glenn's Classic Plant
17 years 6 months ago #4040
by tctractors
Just a few pic's tonight of some long serving " Hire Units " to be found on U.K. sites, any ideas on the power units, more pic's a.s.a.p.
tctractors
17 years 6 months ago #4081
by tctractors
Here's a few more pics of some jobs ive been on recently, D9G a rock crusher and a water well drilling rig. all these jobs were undertaken in the largest workshop in the world with special soft floor and air conditioning. next pics coming soon of the Irish garden tractor
tctractors
17 years 6 months ago #4085
by tctractors
Today I called David Moggeridge to enquire as to his state of play , after a simple slip on a patch of ice a few weeks ago, David is 69 years old 6'4" tall and is only happy when he is busy working on something mechanical,with an earth moving theme, anyhow it seems that he has knocked his replacement hip joint loose , but is able to walk about without to much discomfort, also without the aid of walking sticks, as long as he takes things steady, the Vet says he will re-set his loose joint, some time in the future, so all David has to do is keep breathing and things should work out O.K.
Just thought I would keep C2 informed.
tctractors.
17 years 6 months ago #4105
by David Wills Cat 60
TC,
I'm pleased to hear that Dave is on the mend.
Thanks for the pictures, what's the latest status on your D7 3T, is it still painted green?
17 years 6 months ago #4107
by tctractors
David the D7 has just sat there looking good, as I have just been so busy with other peoples machinery, anyhow my partner in crime ( C. Prosser ) is giving me a few moans, as I realy need to get this old bird back together. I am also restoring a Scania LBS 140 Super 3 axle tractor unit with the hope of taking them both to shows.
tctractors.
17 years 6 months ago #4108
by sprocket
Hi T.C. ,what serial number would that D9 be?looked to be early with the twin air cleaners ,would it have been converted donkey start? .I have had my D8 delivered a couple of days ago ,and have just dropped of the hard front with the martian.Iam starting to save money now as i will need to employ your services ,to split my tracks with that new toy of yours,and i heard you dont come cheap!cheers sprocket.
17 years 6 months ago #4134
by tctractors
The D9G was serial No 66v 2200, as you say it had a few remnants of the donkey engine still to be found if you know were to look, the driver told me he had it stuck real bad a few days befor it started to play up, it took three days to dig it out and pull it out of it's grave, the draw bar clevis broke off with the amount of strain that was put through it trying to winch it out, I only wish I could have seen that, on Sunday I am taking a lowloader into central London (next to the Ritz Hotel) to perform a dummy run of installing some very large work of art into a location, I am looking forward to ripping your old banger to bits sprocket, taking it to bits cost's little, its the bolting it back together that costs the most.
tctractors
17 years 6 months ago #4136
by sprocket
HI T.C ,will b in touch soon and i will let you loose on the old banger,although under supervision,as i dont want to be left with a pile of nuts and bolts!cheers
17 years 6 months ago #4137
by MARTYN WILLIAMS
Hello Sprocket
Glad the D8 has been delevered,will pop around to see it when off night shift.
Russ Kingan rang on Sunday ,he is selling his D7.
Tony and Graham,hope you are keeping well.
Cheers
Martyn
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
17 years 6 months ago #4174
Sprocket,
What's the info on your new D8, any pictures available?
With regards to TC's new toy are you referring to his new hydraulic puller or his new 4lb lump hammer, or both?
