D4 Weight
D4 Weight
17 years 7 months ago #3060
by timbo1946
I have a chance to buy a D4 5T model for scrap price. Has been sitting for 10+ years in present location. Pony is free, couldn't turn main engine. Has a small blade on, can't determine type. All operating levers are frozen in place. I would like to know the weight of the unit. I would like to restore a dozer for play, but would have to be able to move on 14000# gvrw trailer.
17 years 7 months ago #3062
by SJ
I don,t have a listing on your tractor as the parts book doesn,t show it but the 6U tractor which would be about the same is listed as just the tractor as 10,505 lbs. so with the small blade on it you should be well within the 14,000 lb. trailer.
Thank you received: 9
17 years 7 months ago #3067
by ccjersey
I expect you are well under 14,000 total with tractor, blade and associated dirt etc, but trailer GVWR is load AND trailer. Trailer may be 5-6000 of your capacity. Then you need to look at Combined GVWR in the owners manual of the tow vehicle. tractor and blade at 12,000 or so plus truck and trailer
Look up "D4 weight" on the ACME website and you will get a primer on hauling (legally and illegally). D4 would probably best go on 3 axle single wheels or 2 axle with duals, to really haul it with some margin to spare.
17 years 7 months ago #3098
by Toolbox
My 7u D4 with a number 4 toolbar blade, 540 rpm pto, and homemade wooden cab weighs right at 13000 lbs. According to my local elevator scales.
Hope this helps.
17 years 7 months ago #3107
by Paso Bob
My 7U with an ATECO straight dozer weighs 14,370#s across the scale. I haul it on a 20,000# 2 axle gooseneck trailer with dual wheels. It's marginally legal...
D4 Weight
Time to create page: 0.342 seconds
