need bearing source
17 years 7 months ago #2741 by Jack
need bearing source was created by Jack
Who still stocks main and rod bearings for a D2 5U engine, both -0.030. Cat has the rod bearings at $pretty steep, but I'd use them if i can't substantially beat their price and still get quality. I havn't found any mains.
I thought maybe I could run this shaft again standard but when I got in there was water damage on the journals.
Any suggestions will be much appreciated. (I still have a D7 3T/17A wet clutch I'd trade in a second.) Thanks,
Jack
17 years 7 months ago #2745 by Old Magnet
Replied by Old Magnet on topic need bearing source
Hi Jack,
I don't have a source for bearings but this info might help the search.
I wish folks would share more of their bearing sources as it seems to be a constant scramble........or maybe it's a secret.
On an outside chance try www.regalcorp.com
D2, 933, #212 grader Models 3J, 5J, 4U, 5U, 11A, 9T, 79C
Rod Brg. w/rod # 5B419 uses #2F1083
Rod Brg. w/rod # 6F4324 uses #4H3026
Main set w/crank # 7B9079 uses #5F1081
The rod bearings are also the same (match the rod numbers same as D2) for the D4
Models 7J5104-up, 2T, 5T
17 years 7 months ago #2750 by Jack
Replied by Jack on topic need bearing source
Thanks, O.M. I'll give it a shot.
Jack
17 years 7 months ago #2753 by brialin
Replied by brialin on topic need bearing source
I have had luck in the past getting engine parts from a local machine shop that does engine rebuilding. They have catalogs full of parts for any engine you can think of. Of course maybe caterpillar has found a way to keep everything to themselves. Good luck.
17 years 7 months ago #2759 by Jack
Of course these bearings are nothing like a normal insert bearing and would have to come from altogether different manufacturing methods, but that's why they lasted 50 years. I think that's two reasons why the regular bearing houses don't have them. I have the local rebuilder working on it now and he's having no luck so far. Different rebuilders use different sources so maybe something will turn up. Your suggestion is a good one but I already have them on it. Thanks.
Jack
17 years 7 months ago #2766 by Old Magnet
This was a one time ad, never heard from again.
Mite be worth a call.
ACMOC ad
“All Cat Bearings Avail”
“Can reline old shells”
1-800-233-6934
509-999-2199
The Ram Man
Jack Bunton, Pres.
Ram Engine-Vintage Machine Works-RPM Service Center
17 years 7 months ago #2779 by Jack
Gave it a try. That area code is for Washington/mid Columbia area--right across the river from me. I never heard of the outfit. The guy on the other end never heard of it either. I suppose we can pitch that number into the circular file.
We're looking at another option--maybe a good used crank in the bearings that I have instead of a regrind. I'm betting someone rolled a new set of bearings into that engine before they trashed it. The wear in the shells isn't too bad.
Cat wants about $650 for the undersize rod inserts for four rods, close to $700 for standards. I'm avoiding it.
Didn't have a chance to try regalcorp today, may wait. We're prowling Jim's yard for another crank first.
Thanks for suggestions, will keep you posted...
Jack
17 years 7 months ago #2786 by alan627b
17 years 7 months ago #2787 by Bob C
Replied by Bob C on topic need bearing source
Jack,
Ram still has a web site WWW.ramengine.com and the 800 number is the same as posted above.
Bob
17 years 7 months ago #2791 by KidNV
Replied by KidNV on topic need bearing source
OM,
2F1083 $27.48 regal $166.65 cat
4H3026 $non-stock $139.99 cat
5F1081 $out-of-stock, but shows as only part of 5F1073,5F1074,5F1075,1076, cat prices for those, in order, $155.61,$115.56,$203.27,$244.13
Try MotorWarehouse in SAC.. remember the parts sources link in Archives at ACME
