Good day all, I have a "new to me " 112 Motor Greder 68E400 I'm in need of engine valve adjustment specs (probably on this site but I dont know what engine it is other than 4cyl na diesel). The pony motor has had parts try to escape through a window next to a connecting rod, so looking for parts or a replacement pony. Also has power steering box upgrade and the output shaft is sheared at the pitman arm splines. It does run and drive (can steer with camber lean). Thank you for your help.
