D318 Fuel pump question in an 8T grader
Thank you received: 31
1 year 11 months ago #241071
by oldbeek
Fuel getting into the crank case. Looked in my parts book. Only seal I see is at the front of crankshaft of the inj. pump. Seems to simple. Is that the seal that is leaking? How possible is it that the fuel transfer pump is dumping fuel into the crank case. That would be an easy fix also. My 80 yr old mind is getting fuzzy so help me out here guys. D318 engine on a friends 8t cat 12 grader.
Thank you received: 26
1 year 11 months ago #241074
by Delta KJ
A faulty seal between the injection pump and the fuel tower housing is a common reason fuel ends up in the crankcase. The seal is actually an o-ring and it isn't difficult to replace.
Thank you received: 620
1 year 11 months ago - 1 year 11 months ago #241079
by Rome K/G
Takes an 8B4967 seal [o-ring], plus the gasket between the filter housing and pump housing.
Last edit: 1 year 11 months ago by
Rome K/G.
1 year 11 months ago - 1 year 11 months ago #241085
by oldbeek
Thanks guys, With the fuel tower all filled with fuel, I am still confused how fuel can get into crank case. Got out my service manual. It shows the o-ring. Still don't see the shaft that drives the inj. pump.
oldbeek.
1 year 11 months ago - 1 year 11 months ago #241088
by Rome K/G
The shaft drives from the timing gears and goes through the filter housing. That area through the filter housing is open to the front gear case, oil lubes the transfer pump drive gear and inj. pump drive shaft.
Rome K/G.
