Need bolt information 1K6608, 1K6612, 1K6610, 5B5473
Thank you received: 409
1 year 11 months ago #241043
Hi all, (probably Josh : ),
could you please tell me the bolt dimensions on these part #s and the current superseding part #, that are used to attach the HT4 main frame to the D47U track frames. 1K6608, 1K6612, 1K6610, 5B5473
For 5B5473, I make that as 1-8 x 4" Grade 8. I'm unable to find the other bolts although in measuring them, the first two look like 1 1/4-7 x 7"
Thanks in advance
Thank you received: 94
1 year 11 months ago - 1 year 11 months ago #241045
by josh
The 5B5473 is listed 1 x 6-1/2 NC, the 1K bolts are all listed as SPL, do you have any older numbers? I may have better luck with them.
Last edit: 1 year 11 months ago by
josh.
1 year 11 months ago #241048
Hi Josh,
I don't unfortunately. I pulled those numbers from my form 30564, which replaced 1098R and 30496 so it might be in one of those two. I had a look in the member's library and form ue032698 has the same 1K parts numbers as my catalog.
I also looked in the Trackson parts catalog and their part #s are 125A9 and 125-7 - the latter would be the 1 1/4 dia bolt and the former would be the 1" dia bolt. Cat's more recent bolt lookup I have has 7X0410 for the 1" bolt x 4", and 7X0433 for the 1 1/4 x 7, which I think are either close matches or are the actual #s in today's codes
Thank you received: 90
1 year 11 months ago - 1 year 11 months ago #241062
by bruce oz
all these bolts still come up in a search 1K6608, 1K6612, 1K6610, 5B5473 ?
5B5473 – Bolt 1 X 6 1/2 Unc
1K6610 - Alternative (cross code) number:
CA1K6610
1K-6610
1K6610
1K6612 - BOLT 1-1/4-7 X 7"
CA1K6608
1K-6608
1K6608
spare.avspart.com/spare/caterpillar/
bruce oz.
kracked1
1 year 11 months ago #241066
Thanks Bruce, I knew one of those aftermarket sites listed the bolt dimensions but I couldn't remember which and the ones that did come up were next to useless. Well, I'm glad to see that the sizing and thread pitch are what I expected so I'll go pick a pair of each up. These are what hold the back end of the Traxcavator frame to the D4 track frames. There's an inch of movement on my buddy's machine so we need to get that situated quickly
bruce oz
Time to create page: 0.145 seconds
