Clutch slipping v120 forklift
1 year 11 months ago #241034
by Gold Dozer
Surprisingly it shifts and works ok until a load gets applied.the disc came from cat and is the only one listed.judging by the friction plate design/pattern it's for a wet application.the springs could be the issue.only did a short test drive with the new disc installed but the old clutch was worn out to paper thinness.
Thank you received: 42
1 year 11 months ago - 1 year 11 months ago #241037
by restore49
Lipe Holloway has a help line - via telephone +44(0)1706 228 321 or email us at This email address is being protected from spambots. You need JavaScript enabled to view it.
Last edit: 1 year 11 months ago by
restore49.
Thank you received: 26
1 year 11 months ago #241083
by Jack
Brake springs have a coating of paint that will burn off if the springs have been hot enough to weaken them. I don't know about clutch springs. I have seen them with a dab of yellow paint on some spot. Anything like that in general use that any of you know of? This thing gets the old curiosity cranked up.
1 year 11 months ago #241084
by Jack
I went back and looked at the photos again. Does it appear that the clutch fingers are higher than normal at the throwout bearing? And maybe the throwout yoke is pretty far back? That clutch looks pretty well hammered. Is it a reman? Or is it ancient and just got reinstalled on a new disk? It appears that there is a grey paint in the one spring that shows, and it is rust pocked. Could it be that only half of the springs still work? Or less? Can you find a manual that shows a picture of a new, just installed clutch properly adjusted? Can an answer be gotten from a whole list of questions???
1 year 11 months ago #241086
by Gold Dozer
The clutch is not a reman.im guessing it's original. Installed a new disc that came from cat.as far as the finger adjustment goes I can't seem to get enough access to hold the inner screw while tightening the lock nut down.havent found a manual for it.that would definitely help.my springs could be the issue as yhe old disc was really worn down.i don't think the last clutchjob wasn't set properly either.
1 year 11 months ago #241087
by Gold Dozer
There isn't another one like it in this area to compare.might have to call lip hollaway as they are not responding to my email.
Time to create page: 0.143 seconds
