Lang lay vs regular lay cable
Thank you received: 6
1 year 11 months ago #240832
by 1972RedNeck
Putting the blade back on my D9D with a #29 rear CCU. The book calls for lang lay cable but I'm not having much luck finding any. What will happen if I use regular lay cable?
Thank you received: 387
1 year 11 months ago #240839
i would go to a joint that specialises in rigging for cranes and winches. they should be able to help you. the difference is how the cable is wound when its made. and how flexible it is.
does the book specify a diameter and strand count. example is 5/8 dia 10 x 25 strands
Thank you received: 63
1 year 11 months ago #240840
by PhilC
Not much will happen except maybe it won't last as long. Lang lay cable is more flexible which suits CCU's due to the number of sheaves they go around. The main thing is to get the correct number of wires and strands. I usually use whatever is available at the time and the difference in life of the cable is significant.
Thank you received: 620
Thank you received: 279
1 year 11 months ago #240853
by Deas Plant.
Hi, 1972RedNeck.
I don't know where you hail from but this company may be able to help - if you are not living on Jupiter - or somewhere equally remote.
www.fresnowirerope.com/
1 year 11 months ago #240866
thanks rome. confirmed what i thought. most crane cables ive seen are lang lay cables. and yes in operation a regular lay cable would be more like a steel bar when under load were as lang type cables would have more flex as the strands are more towards a 45 deg to centreline than the shallow angle of standard cable.
Time to create page: 0.171 seconds
