- Thank you received: 387
Thanks for that bit of info Mike. My D8 has a number stamped in the side of the block in a similar location but no serial number tag.That number stamped on the block, suggests to me that engine has been worked on at some stage in its life, I have a engine here stamped in a similar way, I think they are workshop repair stamps, perhaps the head was pulled for a valve grind, or a full engine rebuild. Keep in mind your tractor is over 80 years old, and might well be on its second or even 3rd set of cylinder liners, and piston rings, and valves, unless you know the full history of that tractor, assume it has done a lot of hours.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
