D2: I Tried to bite off more than she could Chew, bent the Cutting edge plate?
Thank you received: 14
2 years 1 week ago #240619
by G2D2
Dont know if this cutting edge was loose and I missed it or what the deal is, you can see in the pictures half is tight and half is not, I did stall her and took a chunk of dirt out where I could not see the elevation go up real quick so think I bent this edge, looks like it has been done before on the ip side edge.. Anyone know where to get these new bolts and what they are called? Any tips on blades and cutting edges in general? Had to cut this side bolt off and the main blade metal behind it is really thin!
Thank you received: 90
Thank you received: 409
2 years 1 week ago #240627
You can get the cutting edges, bolts, and nuts from your Cat dealer. I bought a new set for my D2 blade a couple of years ago
G2D2
Thank you received: 191
2 years 1 week ago #240632
by D4Jim
Us Redneck farmers call them plow bolts!!
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
G2D2
2 years 1 week ago #240634
by G2D2
Bruce Oz! could not figure out why my parts catalog did not have the schematic come to find its just the d2 tractor parts book not the bulldozer ! Thank you for the kind post!
bruce oz
Thank you received: 285
2 years 1 week ago #240636
by gauntjoh
Hi G2D2,
We have manuals for 2A and 2S (D2) dozers in the members library.
Membership costs from just $44 per annum and supports this website.
Thank you received: 387
2 years 1 week ago #240639
the bolts are called plough bolts any good bolt supplier will have them or can get them. any place that sells farm implements will have them too. and smear the with a little anti-sieze when installing makes life easier next time.
2 years 1 week ago #240648
by 74A6C
Plow bolts are what I've always known them to be called, no matter if they're on a CAT tractor, Deere grader or Deere mold board plow. I've had decent luck building up frogs (where your wearable edge bolts) using higher tensile welding rods. 8018 and up, by being careful and lots of use of a 7 inch grinder and a helluva bunch of patience. And always put a full set of new bolts in the particular wear piece you are replacing or turning.
2 years 1 week ago #240649
by 74A6C
As always Mr. Gaunt is correct, a membership is nearly invaluable with it's small fee. Parts book availability is well worth the cost.
Time to create page: 0.182 seconds
